How Do You Calculate the Original Mass in a Relativistic Disintegration Problem?
The original mass of a body disintegrating into two fragments with masses of 3.0 kg and 4.0 kg, moving at velocities of 0.8c and 0.6c respectively, is calculated to be 10 kg. The solution involves applying the energy-momentum relation and the relativistic kinetic energy equation. The initial approach using conservation of energy was flawed as it neglected the mass-energy of the fragments. The correct approach incorporates both kinetic energy and rest mass energy to arrive at the accurate original mass.
  • Understanding of the energy-momentum relation in special relativity
  • Familiarity with relativistic kinetic energy equations
  • Knowledge of relativistic momentum calculations
  • Basic principles of conservation of energy in physics
  • Study the derivation and applications of the energy-momentum relation
  • Learn how to apply the relativistic kinetic energy equation in various scenarios
  • Explore examples of conservation of energy in relativistic systems
  • Investigate the implications of mass-energy equivalence in particle physics
Students and educators in physics, particularly those focusing on special relativity, as well as anyone interested in understanding relativistic disintegration problems and mass-energy calculations.
Je m'appelle
A body at rest in a frame of reference S disintegrates into two pieces moving in opposite directions. The masses of each fragment are 3.0kg and 4.0kg and their velocities 0.8c and 0.6c, respectively. Find the mass of the body before it disintegrated. (Answer: 10kg)
1. Energy-momentum relation
E^2 = (pc)^2 + (m_0 c^2)^2
2. Relativistic kinetic energy equation
E_{ki} = m_i c^2 \left(\frac{1}{\sqrt{1-\frac{v_i^2}{c^2}}} -1 \right)
3. Relativistic momentum equation
p_i = \frac{m_i v_i}{\sqrt{1-\frac{v_i^2}{c^2}}}
First I tried using conservation of energy, by taking the energy of the body at rest (1.), with p=0, and equating it to the sum of the kinetic energies of the two fragments (2.), which looked like this
m_0c^2 = m_1c^2 \left( \frac{1}{\sqrt{1 - \frac{v_1^2}{c^2}}} - 1 \right) + m_2c^2 \left( \frac{1}{\sqrt{1 - \frac{v_2^2}{c^2}}} - 1 \right)
This yields m_0 = 3 \ kg which doesn't make sense.
Then it occurred to me that since I already have the answer (10 kg), which was provided in the problem, and both fragments sum up to 7 kg then there's 3 kg of mass missing, so I'm clearly skipping something here.
Any hints?
As far as I can see, you seem to be ignoring the mass-energy of the two pieces that fly apart - I think you're only considering their kinetic energy.
You're absolutely right! Thank you, tomdodd4598
