Relativistic relative velocity
15 replies · 3K views
center o bass
Hi. I'm reading some quantum field theory and I'm a bit rusty in my relativistic kinematics. I stumbled across the formula
[tex]E_1E_2 v_{rel} = ((p_1p_2)^2 - m_1^2m_2^2)^{1/2}[/tex]
where 1 and 2 are two collinearly colliding paritcles with their respective masses and [itex]v_{rel}[/itex] are their relative velocity. My question is; how is this relation derived?
tom.stoer said:
what is the context? what do the indices 1 and 2 mean?
Hi! 1 and 2 are two collinearly colliding paritcles with their respective masses and [itex]v_{rel}[/itex] are their relative velocity.
Is the relation you're asking about the relative velocity?
You should post a better reference. Name the book and the page number, and if possible, link directly to the page at Google Books.
ghwellsjr said:
Are you going to answer my question in post #4?
Yeah of course. I thought that was clear from the title and the statement
"where 1 and 2 are two collinearly colliding paritcles with their respective masses and [itex]v_{rel}[/itex] are their relative velocity."
but yes, it is their relative velocity :)
How are you defining and/or measuring their individual velocities?
I think [itex]p_1p_2[/itex] is the dot-product of the two 4-momenta.
...in terms of components: [itex]E_1 E_2 - \vec p_1 \cdot \vec p_2[/itex], where the spatial dot-product is used.
...in terms of rapidities ["angles" in spacetime]: [itex]m_1 m_2 \cosh(\theta_1-\theta_2) = m_1 m_2 \gamma_{12}[/itex], where [itex]\gamma_{12}=\frac{1}{\sqrt{1-v_{12}^2}}[/itex] is in terms of [itex]v_{12}=\tanh(\theta_1-\theta_2)[/itex], the velocity of object-1 according to object-2, what I would call the "relative velocity" (see below).
So, the quantity under the radical sign on the right-hand side ( [itex]((p_1p_2)^2 - m_1^2m_2^2)^{1/2}[/itex] ) is non-negative, even for small velocities.However, I think the formula in Mandl is incorrect for another reason.
(2nd ed) http://books.google.com/books?id=Ef4zDW1V2LkC&pg=PA129#v=onepage&q&f=false (p. 129, eq 8.9)
(1st ed) http://archive.org/details/IntroductionToQuantumFieldTheory (p. 185, eq 23)
The (proposed) equation in Mandl [for spatially-parallel 3-momenta according to us... i.e. the 4-momenta of the two particles and us are coplanar in spacetime]
[tex]E_1 E_2 v_{rel} \stackrel{?}{=} ((p_1p_2)^2 - m_1^2m_2^2)^{1/2}[/tex]
translates into rapidities as [tex] \begin{align}<br /> (m_1\cosh\theta_1) (m_2\cosh\theta_2) <br /> v_{rel}<br /> &\stackrel{?}{=} ((m_1m_2\cosh(\theta_1-\theta_2))^2 - m_1^2m_2^2)^{1/2}<br /> \\<br /> \cosh\theta_1 \cosh\theta_2 <br /> v_{rel}<br /> &\stackrel{?}{=} ((\cosh(\theta_1-\theta_2))^2 - 1)^{1/2}<br /> \\<br /> \cosh\theta_1 \cosh\theta_2 <br /> v_{rel}<br /> &\stackrel{?}{=} \sinh(\theta_1-\theta_2)<br /> \\<br /> v_{rel}<br /> &\stackrel{?}{=} \frac{\sinh(\theta_1-\theta_2)}{\cosh\theta_1 \cosh\theta_2 }<br /> \end{align}[/tex]
However, I would have expected
[tex] v_{rel} \stackrel{expected}{=} \tanh(\theta_1-\theta_2) <br /> = \frac{\sinh(\theta_1-\theta_2)}{\cosh(\theta_1-\theta_2)}<br /> = \frac{\sinh(\theta_1-\theta_2)}{\cosh\theta_1\cosh\theta_2 - \sinh\theta_1\sinh\theta_2}[/tex]
so that Mandl's formula should probably read
[tex] \begin{align}<br /> (E_1 E_2 - \vec p_1 \cdot \vec p_2)v_{rel} <br /> \stackrel{expected}{=} ((p_1p_2)^2 - m_1^2m_2^2)^{1/2}<br /> \\<br /> (p_1 p_2)v_{rel} <br /> \stackrel{expected}{=} ((p_1p_2)^2 - m_1^2m_2^2)^{1/2}<br /> \end{align}[/tex] in its simplest form.
The further clue that something is wrong with Mandl's formula is that
eq. 8.10a on p. 129, 2ed and eq. 24 on p. 185, 1ed
appears to describe "relative velocity" in the Galilean way as the difference of two velocities.
If there are special cases or approximations being taken, they are not obvious to me.
Did I make a mistake somewhere? in interpretation?
There must be more to this story because Weinberg discusses this in his Quantum Theory of Fields book: p.137 - p.139
books.google.com/books?id=h9kR4bmCPIUC&pg=PA137&lpg=PA137&dq="relative+velocity"
p.139 ... it can take values as large as 2.
Aha!
I see what it is now. It's a terminology confusion.
Mandl's and Weinberg's "relative velocity" is what DaleSpam and others here at PF call "separation velocity"... literally v1-v2.
In terms of rapidities, Mandl's formula is:
[itex] \begin{align} <br /> E_1 E_2 v_{separation} <br /> &= ((p_1p_2)^2 - m_1^2m_2^2)^{1/2}\\<br /> (m_1\cosh\theta_1) (m_2\cosh\theta_2) <br /> v_{separation} <br /> &= ((m_1m_2\cosh(\theta_1-\theta_2))^2 - m_1^2m_2^2)^{1/2} <br /> \\ <br /> \cosh\theta_1 \cosh\theta_2 <br /> v_{separation} <br /> &= ((\cosh(\theta_1-\theta_2))^2 - 1)^{1/2} <br /> \\ <br /> &= \sinh(\theta_1-\theta_2) \\ <br /> v_{separation} <br /> &= \frac{\sinh(\theta_1-\theta_2)}{\cosh\theta_1 \cosh\theta_2 } <br /> \\<br /> &= \frac{\sinh\theta_1\cosh\theta_2-\sinh\theta_2\cosh\theta_1}{\cosh\theta_1 \cosh\theta_2 } <br /> \\<br /> &= \tanh\theta_1-\tanh\theta_2<br /> \end{align}[/itex]
So, while the relative-velocity [itex]v_{rel}=v_{12}=\tanh(\theta_1-\theta_2)[/itex] is a scalar (a Lorentz-invariant quantity),
the separation-velocity [itex]v_{sep}=v_{1}-v_{2}=\tanh\theta_1-\tanh\theta_2[/itex] is not Lorentz invariant.
(As we know, of course, these two quantities are equal in the Galilean case, as well as Galilean-invariant.)
However, [itex]\cosh\theta_1\cosh\theta_2 v_{sep}=\gamma_1\gamma_2(v_1-v_2)=\sinh(\theta_1-\theta_2)[/itex] is a Lorentz-invariant, the "relative celerity". (See http://en.wikipedia.org/wiki/Proper_velocity )
Thus, [itex]E_1 E_2 v_{sep}[/itex] is a Lorentz-invariant... as Weinberg motivates.
Whew... hopefully this clears up the confusion, as well as answers the original poster.
[Ok, great... now back to grading.]
jtbell said:
"Du har enten kommet til en side som ikke kan visas, eller nådd grensen for hva du kan vise av denne boken." :cry:
This sort of error can often be fixed by changing the country part of the domain name (.no) to your own country's code, or to .com. It worked for me with this one. (The message means "you have either come to a page that can't be displayed, or reached the limit for what you can display of this book").
robphy said:
[..] I see what it is now. It's a terminology confusion.
Mandl's and Weinberg's "relative velocity" is what DaleSpam and others here at PF call "separation velocity"... literally v1-v2. [..]
Please leave me out: I use apparently the same definition as Mandl and Weinberg (and Einstein, Alonso&Finn, ..). :-p
(I was going to suggest that it's probably a definition issue, but evidently you figured it out already).
