Relativity of Length: Understanding Length Contraction & Time Dilation
  • Thread starter Thread starter Fernando Rios
    Length Relativity
The discussion revolves around the concepts of length contraction and time dilation within the framework of special relativity, particularly in the context of an unstable particle created in the upper atmosphere and its travel to the Earth's surface. Participants are examining the calculations related to speed, distance, and time as perceived from different reference frames.
  • Mixed
  • Participants are attempting to apply the definitions of speed, length contraction, and time dilation equations to solve the problem. There are questions regarding the interpretation of length in different frames and the calculations leading to apparent discrepancies in results.
Some participants have provided guidance on the correct application of the equations, while others are exploring the implications of reference frames on measurements of distance and time. There is an acknowledgment of confusion regarding the particle's frame versus the Earth's frame, and the discussion is ongoing without a clear consensus.
Participants are grappling with the definitions and implications of length contraction and time dilation, particularly in relation to the rest frame of the particle versus the Earth. There are noted concerns about the formulation of the homework statement and the assumptions made in the calculations.
Fernando Rios
An unstable particle is created in the upper atmosphere from
a cosmic ray and travels straight down toward the surface of the
earth with a speed of relative to the earth. A scientist at
rest on the earth’s surface measures that the particle is created at an
altitude of a) As measured by the scientist, how much
time does it take the particle to travel the to the surface of
the earth? b) Use the length contraction formula to calculate the distance
from where the particle is created to the surface of the earth as
measured in the particle’s frame. c) In the particle’s frame, how
much time does it take the particle to travel from where it is created
to the surface of the earth? Calculate this time both by the time dilation
formula and also from the distance calculated in part (b). Do
the two results agree?
delta_t = delta_t_0/sqrt(1-v^2/c^2)
delta_L = L_0*sqrt(1-v^2/c^2)
a) We use the definition of speed:
v = delta_L/delta_t
delta_t = delta_L/v = 45000 m/(0.99540*3*10^8 m/s) = 1.55*10^-4 s
b) We use the length contraction equation:
L_0 = delta_L/sqrt(1-v^2/c^2) = 45000 m/sqrt(1-0.99540^2) = 469698 m
However, the solution shows the following:
L_0 = delta_L*sqrt(1-v^2/c^2) = 45000 m*sqrt(1-0.99540^2) = 4310 m
Shouldn't the length in the particle's frame be greater?
c) We use the time dilation equation:
delta_t_0 = delta_t*sqrt(1-v^2/c^2) = (1.51*10^-4 s)*sqrt(1-0.99540^2) = 1.44*10^-5 s
We use the definition of velocity:
v = L_0/delta_t_0
delta_t_0 = L_0/v = 469698 m/(0.99540*3*10^8 m/s) = 1.51*10^-4 s
delta_t_0 = L_0/v = 4310 m/(0.99540*3*10^8 m/s) = 1.44*10^-4 s
What am I doing wrong?
v = delta_L/delta_t
t= L_0 / v
because distance is still at the Earth. I read ##L_0=45,000 \ m##
L is distance measured in particle frame of reference
L=L_0 \sqrt{1-\frac{v^2}{c^2}}=\frac{L_0}{ \gamma}
I read ##v=0.9954c,\ \gamma=10.44##
I will leave the followings to you.
Fernando Rios said:
Homework Statement:: An unstable particle is created in the upper atmosphere from
from where the particle is created to the surface of the Earth as
Relevant Equations:: delta_t = delta_t_0/sqrt(1-v^2/c^2)
No. The rest frame of the distance is the Earth’s rest frame. It is therefore contracted in the particle’s rest frame.
Also note that part (c) of the statement is badly formulated.
”In the particle’s frame, how much time does it take the particle to travel”
The particle is at rest in its rest frame and therefore does not travel in that frame by definition. In that frame, it is the Earth’s surface that travels.
Thank you for your answer. It really helped me.
  • · Replies 36 ·
  • · Replies 38 ·
  • · Replies 22 ·
  • · Replies 31 ·
