Remedial kinetic energy equivalency question
The discussion focuses on understanding the equivalency of kinetic energy (KE) in impacts between two objects of different masses. A 100kg object moving at 20 m/s has a KE of 20,000J, while a 10kg object must move at 63.25 m/s to achieve the same KE. Factors such as cross-sectional area and material properties, including rate sensitivity, significantly influence the damage caused by impacts, despite equal kinetic energy. The coefficient of restitution also plays a crucial role in determining energy loss during collisions. Ultimately, variations in contact area and material response can lead to different levels of impact severity and damage.
denver75
I'm working on a demonstration of where I want to show the equivalent result of impacts of two separate masses. I'd like to make sure I am understanding these concepts correctly (it's been more than a few years since my college level physics class).
An object weighing 100kg moving at a velocity of 20 m/s has a KE of 20,000J
To get the equivalent KE from an object that weighs 10kg, I've calculated a velocity of 63.25m/s
Now, here's my uncertainty: does this mean that an impact of the 100kg object moving at 20m/w would create the same amount of damage as the 10kg object moving at 63.25m/s? Assuming that the materials are the same, so the impact distance and rebound would be equivalent. Or are there other factors involved?
Thanks in advance.
cross sectional area might factor in , they have the same kinetic energy but
the smaller cross sectional area would focus that energy to a smaller point.
First, assume that the coefficient of restitution is 1, so that there is no "damage" (energy loss). In this case, both momentum and energy are conserved (the first mass always recoils unless M1 = M2). You have two equations in two unknowns.
Second, solve the same problem where the coefficient of restitution is zero.
Third, solve the same problem with an arbitrary coefficient of restitution.
Beware of using rolling billiard balls, because 2/7 of the total kinetic energy is rotational energy (I = (2/5) m R^2) and is not easily transferred during a collision.
Compare these two drop weight impacts:
Impact 1
Mass = 1 kg
Drop height = 2 m
Speed on impact = \sqrt {2gh} = 6.26 ms^{-1}
Kinetic energy at impact = \frac {1}{2} m v^{2} = 19.62 J
Impact 2
Mass = 2 kg
Drop height = 1 m
Speed on impact = \sqrt {2gh} = 4.43 ms^{-1}
Let's assume that all the kinetic energy of the impacting object (KE) is perfectly converted to elastic strain energy (W) by purely compressing a sample of the same material and dimensions:
W=\int^{\epsilon=\epsilon_{1}}_{\epsilon=0} \sigma d \epsilon = KE
If your sample has a compressive stress-strain profile that does not vary with strain rate, the strain epsilon_1 at which this is achieved (and the subsequent stress that this is achieved at) will be the same for both impacts.
However, if your sample shows strong rate dependency (for instance most polymers) then the fact that one impact occurs at a greater initial velocity means that the material response will generally be stronger and stiffer. That's something to bear in mind when you talk about two equal-energy impacts with the same contact area - rate sensitivity in materials means you will probably see a difference in 'impact severity'.
Also, when you begin to change the contact area between collisions, you will begin to see greater differences in 'impact damage'. The large stresses created by the relatively sharp point of a bullet will create more damage in a structure than a relatively bluff ball bearing of the same mass and impact speed.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
