Report errors and functional problems with PF5
  • Thread starter Thread starter Greg Bernhardt
512 replies · 64K views · last reply
A workaround would be to hit Ctrl+A and Ctrl+C after the edit command and keep it in the buffer.
My problem is that sometimes when I edit a post, if I attempt to italicize, bold or underline even a single word or letter, then everything following also gets italicize or bolded or underlined.
I experimented with this post, but the problem failed to show up here. Murphy's Law.
In the post
https://www.physicsforums.com/threa...in-an-expanding-universe.978978/#post-6247686when I tried to bold "understanding" the problem showed up.
Alerts from mentors remain unread, even if read.
Only way to mark them as read is to mark ALL alerts as read, which is annoying.
Can we at least have a link 'Mark as read' next to alerts like
Your recent report has been resolved: Post in thread tadadada - Thanks, deleted with infraction
in the alerts pulldown (and, dare I ask, in the your account > Alerts page) ?
I too find this very annoying. There is a work-around involving preferences but such a waste of time.
Links in Share this Page are no longer visible:
Works here with an OLD version(43) of Firefox.
EDIT: Well, 'Share this post' works. Haven't found 'Share this page.'
Using an adblocker, Wrichik ?
My adblocker on. . .
My adblocker off. . .
I have found something very strange. Note the name of the vanishing set!
1. Chrome - before interpreted
2. Chrome - after fully loaded (and interpreted)
3. Opera
I haven't checked it on a "naked" version of chrome, so it might well be due to an add-on.
I use version 78.
But why this specific formula? And why can it still be recovered via the process: mark and show Math as TeX commands? I stumbled upon it by chance and wanted to correct it as I saw it didn't need a correction. And it is reproducible: loaded correctly, interpreted wrongly.
It probably doesn't need fixing, but it's "funny" and / or "annoying" in a way. I would normally say "tell the developers", but as it is worldpress ...
Maybe I should send a note to Google. Not that this would change a lot ...
Shows here on an old, Ver.43 Firefox.
  • Wow
Greg Bernhardt said:
That's 4 years old, why not update?
That requires updating Windows version - that requires replaceing printers, scanner, etc, because drivers are not available for newer Windows - then there are some commercial applications that would need replacing; overall a few $,$$$.
Also, much of the customization I've done for convenient workflow and maintenance is not available because current versions have locked down customization to reduce support needs, and for "improved security." For instance printers used to allow specifying custom paper sizes and margins, from what I've found, that is rare these days.
Overall, "It works for me"... most of the time.
Orodruin said:
Workflow
Lol. . .
  • Haha
This is one is a bit closer to what happens.
https://xkcd.com/1174/
I recently tried to order some Hard Disk Drives from the manufacturer. After each step in the process was filled in, there was a "Continue" button. I got thru the
Model No.
Quantity
Name & Address
Payment Method
Clicking the Continue button after each.
That last one would high-light but do nothing else. Wouldn't even send anything over the Internet. Therefore I couldn't get to Place Order.
I tried this on two computers and 5 browsers, no luck.
I tried their Customer Service and they have no way to order by phone.
I finally grabbed my wife's tablet and placed the order.
I'm not sure whether to call this "Advance to The Rear" or "Progress, Our Most Important By-product". :H
Ordinarily, I would find a different supplier. In this case other sources were 27% higher. And by Creating Account on their site, they took off another 10%.
Oh well.
Cheers,
Tom
Awhile back we removed the base URL for the "Forum" navigation link forcing the drop down every time. Unknown to me this actually messed up our breadcrumb navigation because the root breadcrumb inherits the URL from the "Forum" navigation link. For now, I've restored the link so to get the drop down items you must click the down arrow. I am looking for another solution.
If I may suggest three changes for a future version, I'd like to say
  • A cancel button in the reply mode which deletes the edit field from the buffer would be great. I often use it if I want to copy something, because +quote does not work as it destroys the MathJax code. Unfortunately this keeps the entire thing in the buffer if I return later. Sometimes I delete the edit box manually, insert ".", and keep it open for a while, just to "delete" this buffer.
  • A navigation path back from the page "Watched threads" to e.g. "Threads with no replies" (1) would be great. Now we have only the general frame, no sub-navigation as on (1).
  • A post-wise "mark read" option in the drop down menu of the "Alert" button would be convenient.
Indeed !
How come a user name without any J gets a default avater with a J ?
Currently 3:26 EDT navigating on forum takes many minutes. e.g. it took 7 minutes to access this thread.
The webserver had good response times, but the database was very busy I guess.
