Resistance, Voltage, and current
6 replies · 2K views · last reply
Cici2017
Current-voltage graph of a component: a straight line through the origin rising from V0 to V1, with dashed guides marking I1 on the current axis and V1 on the voltage axis, followed by a table of four options for resistance at V1 and how it changes.
I chose A, I understand how the resistance is the gradient, but if it is the gradient and the gradient is constant , shouldn't the resistance stay constant? (But the answer is B)
Please help~thanks a lot~
Resistance cannot be defined for a nonlinear component.
There is "static resistance" and there is "dynamic resistance" but there is no "resistance".
Can you please explain a bit more? What does that mean in the context of this question? Thank you!
It means the question should have specified static or dynamic resistance.
V/I is the "static" or "chordal" resistance. If that is meant the answer would be D.
dV/dI is the "dynamic" or "differential" resistance. If that is meant the answer would be A if we take the right derivative at V0 but B if we take the left derivative.
In short, silly question.
