Quote; "will it be a function of wire length , coil inductance and coil capacitance ? "
Yes. The wire used to wind the coil has capacitance to itself and to the environment. It is like a leaky transmission line. The end capacitance will be important. You must specify the details and wavelength in order to know what will be important. Will you match the transmitter to the antenna coil? or just drive it with a fixed voltage RF.
Every inductor has multiple resonant frequencies for example the capacitance between the ends with the whole inductance, or the capacitance between two turns and the inductance of one turn, or every combination in between.
At the same time the wire used to wind the coil has a physical length and an average dielectric constant of the insulation. From that you can find a transmission line velocity factor, and determine the resonant frequency of the coil as a half wave dipole.
Coil self resonance is a "red herring" topic. If you engineer a rational resonant circuit with a capacitor, it will work better as an antenna than will a simple unterminated coil.
