Response delay in Capacitive Humidity Sensors
Capacitive humidity sensors show a delay in response to humidity changes, even when the relative humidity stabilizes in a closed chamber. This delay, lasting several minutes, is attributed to the time it takes for humid air to diffuse into the capacitor's gap, affecting capacitance. The AD7150 board used for measurement has a rated response time of 10ms, which may not be suitable for detecting slow environmental changes. Suggestions include experimenting with different capacitor configurations, such as flat spiral designs, to improve responsiveness. The discussion highlights the complexities of measuring capacitance changes in varying humidity conditions.
apj_anshul
Hello,
A project I am working on currently requires me to test how capacitors in our circuit react to change in Humidity. As expected, the experimental results suggest that capacitance goes up with increasing humidity, as the electric permitivitty of air surrounding capacitor increases.
However, I also see a curious thing - there is a delay of a few minutes before capacitor responds to change in Humidity. I am conducting these experiments in a closed humidity chamber. I can tell the delay comes from the capacitor because even when chamber's relative humidity display stabilizes to a constant RH value, the capacitor still takes some sizable amount of time before it settles down. This delay is also observed in commercial humidity sensors that use capacitors.
One would expect the capacitance to change immediately, as permittivity of air changed as soon as humidity changed. What causes this delay then?
P.S. Btw, my capacitors are simple two plate capacitors, with no dielectric between them except air. So, any change in capacitance can be safely assumed to come only from changing properties of air.
What are you actually measuring that enables you to say that the capacitance is changing?
I am using AD7150 board to measure capacitance (analog[dot]com/static/imported-files/data_sheets/AD7150.pdf). As far as I know, the board applies a excitation voltage to the capacitor and reads the charge to determine capacitance. I then scan the hex values returned by the board and convert them into capacitance. The manufacturer rates the board's response time at 10ms.
I would suspect that the 10ms response time is that related to a fast change in capacitance such as when a finger comes close to disrupt the capacitance field of the sensor and not to slow changes in environment brought about by temperature or humidity.
Perhaps the board up is incorrectly to detect these slow changes or perhaps slow changes are impossible to detect with this board through its own environmental adaptive internal circuitry and algorithms, which is needed so that the envionment does not falsely trigger the sensor and board in a real life application such as a touch screen or keyboard.
You could try another arrangemnet of capacitor such as a flat spiral or similar so that the humidity acts on all of the capacitor and does not have to work its way into the space between two flat plates ( which should be pF but you do not say specs of your capacitor ) as one way to test if that affects your readings.
Just shooting somewhat blindly here to give you some ideas to think about if yo have not already.
What is the separation d, and ratio of plate area A to d? If d is small, and A/d very large, then it can take considerable time for humid air to diffuse into the gap and equilibrate.
I do not have a good working knowledge of physics yet. I tried to piece this together but after researching this, I couldn’t figure out the correct laws of physics to combine to develop a formula to answer this question. Ex. 1 - A moving object impacts a static object at a constant velocity. Ex. 2 - A moving object impacts a static object at the same velocity but is accelerating at the moment of impact. Assuming the mass of the objects is the same and the velocity at the moment of impact...
  • · Replies 152 ·
10K
31K
