Right angle force on perfectly stretched string
  • Context: Graduate
  • Thread starter Thread starter xtimmyx
    Angle Force String
The discussion revolves around the theoretical implications of applying a vertical force to a perfectly stretched, inelastic string that is horizontally oriented between two supports. Participants explore the resulting forces on the supports and the behavior of the string under these conditions, engaging in a conceptual examination of mechanics.
  • One participant proposes a scenario where a vertical force applied to the middle of a perfectly stretched string results in an infinite horizontal force on the supports, questioning the physical implications of such a situation.
  • Another participant argues that from a classical statics perspective, the scenario is nonsensical unless the laws of mechanics are redefined, emphasizing that the string cannot remain stable under the described conditions.
  • A later reply clarifies that the string can bend but maintains a constant length, suggesting that increased tension occurs as the string becomes more stretched.
  • One participant references a climbing formula indicating that tension approaches infinity as the angle of the string approaches 0º, contributing to the discussion of the limits of conventional mechanics.
  • Another participant notes that while the mathematical expression suggests infinite tension, it is not a definable quantity at an angle of 0º, raising concerns about the relevance of the climbing formula in this context.
  • A further contribution questions whether the behavior of a chain, which has zero elasticity, would differ from that of the string, suggesting that a stretched chain would not fail under similar conditions.
Participants express disagreement regarding the implications of the scenario, with some asserting that the situation is nonsensical under conventional mechanics, while others explore the theoretical limits and behaviors of the string and similar materials. No consensus is reached on the validity of the original claim or the applicability of the climbing formula.
Participants acknowledge limitations in their assumptions, particularly regarding the nature of the string and the definitions of tension and force in the context of the scenario. The discussion highlights the complexities of applying classical mechanics to hypothetical situations.
xtimmyx
Right angle force on "perfectly stretched string"
I have a theory which although physically impossible I would like to know some sort of answer to.
Image a string stretched between two trees. The string is perfectly stretched, totally horizontal, and has no elasticity, but can bend as a normal string.
My theory is that when a vertical force is applied to the middle of the string, no matter the size, the horizontal force upon the trees from the string is infinite. Or impossible to calculate.
I know that there is no such thing as a totally inelastic string and so on, but what would physics be without "what if´s"? :)
I've attached a picture of the problem with some units to it if someone would like to calculate it.
From an usual classical statics approach it is a non-sense, as you said, so short answer can be given to you. If you want to theorize about this you´ll need to redefine laws of mechanics.
If use of "conventional" machanics at your example, this is what happens:
If string is stable at that configuration (horizontal) then all of its points are, including the one were the force is aplied and so we focus on it.
The conventional 2-D static stability condition for this point is
\sum\vec{F}=\vec{0} \Leftrightarrow \sum F_x=0 \sum F_y=0
And by definition we have
\sum F_y=-1 N as seen in the picture, because you assume that the string doesn't bend (well in fact you don't but is implicit since you say it's "perectly stretched" and "has no elasticity") and so no more forces act upwards in such a way they would annul the exsisting force.
Therefore, because of Newton's 2nd law the string have to be moving, here you have your non-sense.
Thank you, however I might have used the wrong words to describe it when talking about elasticity. What I mean is that the string can bend just like a normal one. But that the string's length is constant.
For example, If you have a hammock hanging between two trees, as far as I know, the less stretched the hammock is (more "loose" or what you would call it"), less force from it is acted on upon the trees, right?
Therefore my assumption is that as the hammock/string get's more and more stretch (by increasing the distance between the trees or shortening the hammock/string), the force on the trees would increase and ultimately reach "infinity" or not calculable.
A colleague of mine who is a climber made some interesting points about this, and also found the formula for calculating load on the anchor points. And according to that formula, the tension on the string goes towards infinity as the angel approaches 0º. Se link below for the formula (under equalization):
http://en.wikipedia.org/wiki/Anchor_(climbing)#Equalization
Yes sure it does, but remember that infinity is not a quantity. What is meant by the mathematical behavior of that expression is that, considering "conventional" mechanics laws the tension of the string is arbitrarily high as you set the angle arbitrarily small. But at angle=0º force is not defined since 1/0 is not a real number.
I already considered the string with constant length for my conclusion above :)
Salutations
Salutations
I think Zaphys may have a point here, the question becomes whether or not the anchor formula that was provided is still relevant in this case. It seems hard for me to imagine that is still true. For example, what about a chain? A chain would have zero elasticity and in the limit of small link size would be equivalent to your string. Yet, I can't imagine that a stretched chain would break or bring down its supports if you were to hang a small or even appreciable amount of weight in the middle.
  • · Replies 66 ·
  • · Replies 22 ·
  • · Replies 26 ·
