Right hand rule finding direction of magnetic force
The discussion focuses on determining the direction of the resultant magnetic force on a horizontal conducting ring carrying current I, placed above a strong magnet. The right hand rule is applied to find that the magnetic force, resulting from the interaction of the current and the magnetic field B, points downward at an angle θ below the horizontal. The analysis confirms that while the vertical components of the forces from opposite segments of the ring add together, their horizontal components cancel out, leading to a net downward magnetic force on the ring.
  • Understanding of the right hand rule for magnetic forces
  • Familiarity with magnetic fields and their interactions with current-carrying conductors
  • Knowledge of vector cross products in physics
  • Basic principles of electromagnetism
  • Study the application of the right hand rule in various electromagnetic scenarios
  • Explore the concept of magnetic field lines and their orientations
  • Learn about the effects of varying angles in magnetic force calculations
  • Investigate the implications of magnetic forces on different geometries of current-carrying conductors
Physics students, educators, and anyone interested in understanding the principles of electromagnetism and magnetic forces acting on current-carrying conductors.
JosephK
A strong magnet is placed under a horizontal conducting ring of radius r that carries current I as shown in the figure below. The magnetic field makes an angle θ with the vertical at the ring's location.
(b) What is the direction of the resultant magnetic force on the ring?
to the left
to the right
upward
downward
into the screen
out of the screen
Right hand rule
What have you tried?
Where are you stuck?
Crossing L and B from equation F = ILXB , where L is pointing in the same direction as current, magnetic force would point in a downward angle.
To point straight downwards the magnetic force, B has to point in a direction perpendicular to the current, although here it is pointing at an angle. So, is the B pointing not straight downwards but downwards at an angle?
Umm...remember that the force is always perpendicular to both the current and the magnetic field. In the right hand rule, your thumb is the force, pointing finger is the current, and your middle finger is the field.
What are you having trouble with?
Consider any small piece, ΔL, of the ring, where the direction of ΔL is the same as the direction of the current, I. Using the right hand rule for the magnetic force, ΔF = IΔL×B, the direction of which is outward and downward at an angle of θ below the horizontal.
What is the result of summing ΔF over the whole ring?
The curvy B field throws me off.
At the points where the B field intersects the ring, B is at an angle θ from the vertical, pointing outward from the ring (as well as upward).
Consider two small pieces of the ring located directly opposite each other, (ΔL)1 & (ΔL)2. Now take the magnetic force on each and add these forces. The vertical components add (they're both downward) and the horizontal components cancel.
What does that tell you about the net magnetic force on the ring?
The magnetic force is downward.
This is how I curl my fingers, correct?
Would the magnetic force point inwards and downwards or outwards and downwards?
Thank you
