Rigid Body Rotation: Calculating Load Supported by Pivot
The discussion focuses on calculating the load supported by a pivot when a wooden plank is supported at one end and subjected to gravitational forces. The key conclusion is that the reaction force at the pivot, denoted as N, equals Mg/4, where M is the mass of the plank and g is the acceleration due to gravity. The analysis involves applying Newton's second law and understanding torque and rotational inertia, specifically using the moment of inertia I = 1/3 * M * L^2 for the pivot point. The acceleration of the center of mass is determined to be 3/4 * g.
  • Understanding of Newton's second law of motion
  • Familiarity with torque and its calculation
  • Knowledge of moment of inertia, specifically I = 1/3 * M * L^2
  • Basic principles of rigid body dynamics
  • Study the application of Newton's second law in rotational dynamics
  • Learn about torque calculations in various pivot scenarios
  • Explore the concept of moment of inertia for different shapes and axes
  • Investigate the dynamics of systems with multiple supports and pivots
Students studying physics, particularly those focusing on mechanics and rigid body dynamics, as well as educators seeking to explain concepts of torque and rotational motion.
wolf party
imagine a thin length of wood supported by two supports, one at either end. One support dissapears and the other turns into a pivot (as gravity acts on the wood). Show that the load supported by the pivot is Mg/4.
i don't know where to start due to my confusion on forces with rotation. i know the plank is acted on by gravity at its CM, and its moment of inertia about its CM = I=1/12*M*l^2.
I know there is a reacton force at the Pivot, and this is the force i need to calculate, but i don't know what to consider first, a nudge in the right direction would be helpful!
Start by figuring out the acceleration of the center of mass. Hint: Apply Newton's 2nd law to the rotation.
F=ma -> TAU = I*ALPHA
TAU = (1/12*M*l*l)*ALPHA
so ALPHA = TAU/(1/12*M*l*l)
so a = (TAU/(1/12*M*l*l)) * (0.5*l) ? where a=ALPHA*(0.5l)
(1) It pivots about one end, not the center of mass, so correct the rotational inertia.
(2) What's the torque about the pivot?
TAU = (1/3*M*L*L)*ALPHA
the torque about the pivot is mgl/2 ?
Good. Keep going.
so the acceleration due to gravity is a = 3*TAU/2*ML at the CM
and the torque about the pivot is mgl/2
so m*a = TAU*(1/2*l) ?
Good. So what's the acceleration of the center of mass? (Don't call it "acceleration due to gravity".)
Once you have the acceleration of the center of mass, apply Newton's 2nd law for translation. What forces act on the wood?
is the acceleration ofthe CM just 3TAU/2mL again
the reacton force at the pivot and mg at the CM are the forces on the wood
R = 0 because mgl/2 (where l = 0) = 0
therfore ma=mg ?
acceleration at CM = 3/4*g
But you know the torque, so eliminate Tau from this expression.
Good.
therfore ma=mg ?
No. Apply Newton's 2nd law. What's net force? The acceleration?
Good!
the force at the CM=3/4*mg
Net force at pivot = force at CM ?
That's the "ma" part of "Fnet = ma". But what's Fnet?
No. Two forces act on the wood (you named them earlier). Combine them to get the net force.
Fnet = mg + mgl/2
FNet = N - mg = 3/4mg
therfore N = 1/4mg ?
Careful. As written, this implies that N = 7/4mg. But the acceleration is downward, thus negative: N - mg = -3/4mg.
Yep.
