Is fλ an Automorphism of the Rational Numbers Group?
AllRelative
*This is from a Group Theory class
**My secondary aim is to practice writing the math perfectly because I tend to loose a lot of points for not doing so in exams...
Let λ ∈ Q*
fλ : Q → Q defined as fλ(x) = λx
a) Show that fλ is and automorphism of the group of rationals with the sum operation (Q,+)
Let f: (G,*) → (G', ⋅)
e is the neutral element of G
e' is the neutral element of G'
The definition of homomorphisms:
f is a homomorphism if
f(x*y) = f(x) ⋅ f(y) , ∀x,y ∈ G
f is injective ⇔ ker(f) = {e}
f is surjective ⇔ Im(f) = G'
Let's show that fλ is a homomorphism.
Let x,y ∈ Q
fλ(x+y) = λ(x+y) = λx + λy = fλ(x) + fλ(y)
which proves that fλ is a homomorphism.Let's show that fλ is injective.
The neutral element of Q is 0.
0 = λx ⇒ x = 0 because λ ≠ 0
We can therefore write Ker(fλ ) = {0} which proves that fλ is injective.Let's show that fλ is surjective.
Every element y of Q can be written with the form λx where x∈Q.
This means that Im(fλ) = Q.
This proves that fλ is surjective.Finally, we proved that fλ is a endomorphism that is injective and surjective. This is the definition of an automorphism.
Let λ ∈ Q*
Let x,y ∈ Q
Right so far. I would have written in the surjective part: Every element ##y## can be written ##y=1\cdot y= \lambda \cdot \lambda^{-1} \cdot y = f_\lambda(\lambda^{-1}y)## to actually show the preimage.
In general, you will have to consider more points in a proof:
  1. well definition
  2. domain
  3. codomain
  4. homomorphy
  5. injectivity
  6. surjectivity
The first point comes into play when there are more than one possible images. E.g. if we have ##f: \mathbb{Q} \longrightarrow \mathbb{R}## defined as ##f(x)=\,##decimal representation of ##x##, then we want to be sure that ##f(1/2)=f(2/4)##. This is no problem in your example, and also the points 2. and 3. are obvious, but in general should be considered, because if only a rule for a function is given, it's sometimes not automatically clear that the image belongs to the claimed domain.
Likes AllRelative
  1. well definition
  2. domain
  3. codomain
  4. homomorphy
  5. injectivity
  6. surjectivity
Thanks a lot man! This is exactly the kind of insights I was hoping for.
