Ring and Sphere Linear Expansion
The problem involves a copper ring and an aluminum sphere, focusing on thermal expansion and heat transfer as they reach thermal equilibrium. The scenario includes specific measurements and properties of the materials involved, such as their coefficients of linear expansion and specific heats.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the relationship between the diameters of the ring and sphere at equilibrium, the equations for heat transfer, and the calculations for final temperature and mass. There are questions about the correctness of the arithmetic and potential rounding errors in calculations.
Some participants are verifying their calculations and discussing discrepancies in their results. There is an acknowledgment of possible errors in arithmetic and rounding, but no consensus has been reached on the correct mass of the sphere.
Participants are working under the constraints of the problem's parameters and the requirement that no heat is lost to the surroundings. The discussion reflects uncertainty about specific numerical results and the methods used to arrive at them.
Haptic9504
A 25.0 g copper ring at 0°C has an inner diameter of D = 2.71585 cm. A hollow aluminum sphere at 88.0°C has a diameter of d = 2.72019 cm. The sphere is placed on top of the ring (see the figure), and the two are allowed to come to thermal equilibrium, with no heat lost to the surroundings. The sphere just passes through the ring at the equilibrium temperature. What is the mass of the sphere? The linear expansion coefficient of aluminum is 23.0 × 10-6 /C°, the linear expansion coefficient of copper is 17.0 × 10-6 /C°, the specific heat of aluminum is 900 J/kg·K, and the specific heat of copper is 386 J/kg·K.
http://edugen.wileyplus.com/edugen/courses/crs7165/art/qb/qu/c18/fig18_34.gif
[tex]Q = cm \Delta T[/tex]
[tex]\Delta L = \alpha \Delta T L_{0}[/tex]
Since at equilibrium the sphere passes through the right that would mean that d = D at equilibrium, being that the ring acquires heat and expands while the sphere loses heat and shrinks. I made [tex]L_{f}[/tex] be the final diameter of the two.
For the sphere: [tex]L_{f} - 2.72019 = (2.72019)(23E-6)(T_{f} - 88)[/tex]
For the ring: [tex]L_{f} - 2.71585 = (2.71585)(17E-6)(T_{f} - 0)[/tex]
Solved for Lf and set them equal, solving for T, getting 68.82 celsius.
Heat lost by the sphere = Heat gained by ring.
[tex]cm \Delta T [sphere] = cm \Delta T [ring][/tex]
[tex](900)(m)(88 - 68.82) = (386)(0.025)(68.82)[/tex]
Solving for the mass, m, I get 0.038 kg, which is marked as incorrect.
Not sure what I am doing wrong, be it the whole approach or some minor thing I am overlooking.
Your set-up looks good; double check the arithmetic, and if nothing shows up, holler, and I'll double check it.
I have gone over it a few times, keep getting the same answers. :(
I get 71.10 = Tf. You might try looking for places where you or your calculator might have rounded or truncated numbers on intermediate steps.
Sure enough, that was it. Leave it to my graphic calculator to lead me askew. Thanks!
24K
