RLC circuit -- Phasor Transfer Function calculation
9 replies · 4K views · last reply
Franklie001
For the RLC circuit shown above and sinusoidal input voltage, derive the theoretical expression for Vout/Vin (frequency response) using phasors. Also, give the expression for the resonant frequency of the circuit.
Calculate the resonant frequency for L=10mH, C=10nF, R=50 ohm
Vout/Vin
Good morning,
I need some help solving those two question. I've attached my attempted solution below. Could i solve the transfer function any further?
Thank you for your help
Circuit schematic of a series RLC network labelled Experiment 5 - RLC circuit: source Vin at angle 0 degrees, series inductor L and capacitor C, then resistor R to ground, with output Vout taken across R.
Photo of a printed exam page with a boxed question reading: Calculate the resonant frequency for L = 10 mH, C = 10 nF and R = 50 Ω. Page number 4 appears below.
Handwritten derivation of a transfer function V_out/V_in = Z_R/(Z_L+Z_C+Z_R), simplified step by step to jwRC/(1 - w^2 LC + jwRC).
Hi,
From the "using phasors" in the problem statement, I suspect you are asked to derive an expression that clearly shows amplitude (i.e. ## \left | {V_{R}\over V_{in}} \right | ## ) and phase difference.
Frequency response analysis in Finite Element Analysis (FEA) is used to calculate the steady-state response due to a sinusoidal load applied to a structure at a single frequency. It is a specialized type of transient response analysis that is extremely efficient to solve a very specific type of model.
I think in RLC circuit the equation has to be:
VL+VR+VC=f(t) if no load is out. f(t)=F1sin(ωt)+F2cos (ωt)={F}e^iωt
Then the derivate will be Ld2i/dt2+Rdi/dt+i/C=-ω^2{F}e^iωt
thanks for your response. Could i ask why you derivate the expression? I'm sure that question asks to solve for the frequency response Vout/Vin of the circuit and its resonant frequency.
I had an attempt at it but unsure how to derive the expression for the resonant frequency?
Also, in the second question, I've been given a value of the resistor to calculate the resonant frequency. Could i ask why? Isn't the resonant frequency condition is XL = XC ?
Thanks again
The circuit will have a maximum ## \left | {V_{R}\over V_{in}} \right | ## at resonance.
Work out that expression and ##\omega_{res}## can be found. Rather easily.
Franklie001 said:
Could i ask why?
Perhaps to confuse you ?
Work out that expression and ##\omega_{res}## can be found. Rather easily.Perhaps to confuse you ?
Hi, thank again for your help. I really appreciate it
Just to clarify ..isn't Vr/Vin what i was trying to find?
Also, It looks to me to be a bandpass filter from the expression found previously.
Also, how would you simply the expression for Vout/Vin for transfer function?
Yes, this is the common answer and it works well for highly resonant systems (i.e. high Q, low damping). The real answer does depend a bit on the losses (resistance), but I'm not sure they really intend for you to account for that. For the values given the difference is quite insignificant.
https://en.wikipedia.org/wiki/RLC_circuit#Overdamped_response
Yes. From the "using phasors" in the problem statement I conclude your textbook (or notes) should have something along those lines. Also, ##V_{in}## is given as a phasor: ##V_{in}\ \angle \ 0^\circ##.
So an answer along these lines (or any suitable other) seems indicated.
Yes. The frequency characteristic ##\left | {V_{R}\over V_{in}} \right |## as a function of ##\omega## shows a peak at the resonance frequency.
That, for me, is the essence of the job (your job) at hand ! :smile:
And your link in #8 is not very useful in this context.
Your work in post #1 is more or less the start of an algebraic analysis (an approach that I strongly support; much better in an introductory stage (correct me if I am wrong, but I estimate you are still in that stage).
So you have $$ {V_{R}\over V_{in}} = {R\over R + j\left ( \omega L - \displaystyle {1\over \omega C} \right ) }
How can you write this in the form the exercise seems to prefer: ##A\ \angle\ \phi## ? ( Note that I tried to help a little bit by writing the numerator in this way :wink: )
Thank you for the help I ll read this as soon as I can
