Rocket Calculations, wind resistance, Rectangular hyperbola
The discussion revolves around the calculations related to rocket trajectories, specifically focusing on the effects of thrust, wind resistance, and gravitational forces. Participants explore the mathematical modeling of rocket flight paths, including the transition from hyperbolic to parabolic motion as thrust ceases.
  • Some participants propose that rockets follow the path of a rectangular hyperbola when thrust exceeds their mass, while they fall along a parabolic path when thrust is no longer produced, complicated by wind resistance.
  • One participant questions whether the angle of thrust changes during flight, suggesting it may need to be tangential to the instantaneous velocity vector.
  • Another participant discusses the impact of the rocket's center of gravity on its trajectory and proposes a mathematical model involving a fractional index to describe the flight path.
  • Concerns are raised about incorporating wind resistance into the equations, with a participant seeking methods to adjust their models accordingly.
  • One participant mentions the need for three points to calculate a parabola, expressing uncertainty about how to derive these points given limited data.
  • A specific scenario is presented involving a rocket launched at a 45-degree angle, prompting questions about calculating landing distance and maximum height while considering air resistance.
  • Participants express difficulty in finding solutions due to the complexity of changing thrust angles and the influence of gravity on the rocket's trajectory.
  • There is a suggestion that derivatives could be used to find the angle of thrust, although concerns about the accuracy of the proposed equations are noted.
Participants express various viewpoints on the modeling of rocket trajectories, with no consensus reached on the correct approach or the impact of wind resistance. The discussion remains unresolved regarding the best methods to incorporate these factors into calculations.
Limitations include the dependence on assumptions about thrust angles, the effects of gravity, and the complexity introduced by wind resistance. The discussion highlights the challenges of accurately modeling rocket flight in a two-dimensional space.
This discussion may be of interest to those studying rocket dynamics, aerospace engineering, or anyone involved in mathematical modeling of physical systems, particularly in relation to motion under varying forces.
3physqs
The Basis of this question is that:
* Rockets launched at an angle follow the path of a rectangular hyperbola when thrust greater than their mass is produced.
* That rockets fall in the path of a parabola when thrust is no longer produced, this only applies when the rocket has both x and y inertia, however wind resistance skews this fall
given a rocket that produced a constant thrust of T, was launched at a angle of theta, and burnt for a time period of M, and any other variables, is it possible to calculate where the rocket will land?
The rocket flight is illustrated using MathGV. Come one Can anyone answer ?
The solution to this question is probably way out of my scope (and yes, I'm nearly certain you can express the range of the rocket in terms of the variables given), but I would like to give it a shot.
Before I begin, I'm unsure about one thing so I need clarification on that: When the rocket is launched at an angle theta, the thrust is obviously being produced at that angle too. However, as the rocket moves through its path of projection and is affected by gravity, does the thrust angle change? Maybe the angle the rocket is pointing at is always changing to be tangential to its instantaneous velocity vector?
I hope I'm being clear.
Hi Metallic,
Due to the rockets center of gravity not being where the thrust is being produced, gravity will affect the direction that the rocket is travelling, however as the rocket becomes faster and faster, the change in direction per distance is lessening, so therefore i deduced that the flight of the rocket must follow a graph like a east west hyperbola, or x to the power of a fractional index.
my working is that:
picture 1
converting the launch angle to a gradient
tanθ = y1/1
therefore tanθ = y1
rise over run tanθ/1 = tanθ
finding the power of X
facts we know:
as a guess (1 - gravitational constant/acceleration of rocket). because the power will never go below 0, if the gravitational constant of the rocket is greater than the acceleration of the rocket it will not launch
Guessed equation
f(x)=tanθ(x)[tex]_{\frac{gravitational constant}{acceleration of rocket}}[/tex]
thanks for your response
if the equation is right:
f(x)=tanθ(x) ^ gravitational constant/ acceleration of rocket. this equation does not factor wind resistance. how could this be added ?
Given this equation how can one work out the parabola that if formed from the decent when the rocket is no longer firing, if i have one point on the parabola which is the vertex, and x and y forces at that point, taking into account wind resistance?
thanks to whoever replies
sorry guys
f(x)=tanθ(x) ^ 1- gravitational constant/ acceleration of rocket
i have done some research and figured that the equation of a parabola can be calculated with 3 points on the parabola, however i only have one point and the x and y forces.
anyway i have made an excel which with three points you can calculate the equation of a parabola, it is attached
this is for the stage where the rocket is no longer generating thrust
the theory is that if there were three points infinitesimally close, calculated using the vertex and the changing x force and the changing y force, the reason they should be close is because of the effect of air resistance on the calculation,
for anyone who can figure the first section of the problem
when the second root of the parabola is generated this should be where the rocket hits the ground, apart from the effect of air resistance
so the question should be modified to state,
how can air resistance be taken into account into the first and second part the problem given that air resistance is a squared relationship,
i am not familiar with vector mathematics or complex numbers :( but i am sure that is the key to solving this problem. any engineers?
once this problem is solved i plan to test the accuracy of the results with model rockets, given they produce constant thrust
using all the ideas i had and using your own knowledge could anyone solve the following question showing how they did it?
in a 2 dimensional model (x,y)
a rocket is launched on a flat plain, at a angle of 45 degrees with the ground, there is no change in air pressure as it rises the starting air pressure being 101.33 kpa, the rocket fires for 10 seconds producing a constant thrust of 50 Newtons, the rocket has a mass of one kg and this does not change as the combustion of the rocket proceeds, taking into account air resistance, what is the x value of the landing point? how many km does the rocket travel?, what is the highest point the rocket reaches?
thank you to whoever replies
What's really hindering any progress for me to find a solution (although I can only offer an approximate solution at best given all the variables) is the difficulty posed by the changing angle of thrust. I was going to assume the centre of gravity is in the centre of the rocket, but this doesn't help tell me how quickly it "flattens out" with respect to the horizontal.
It would depend on many factors and frankly until we figure this out, giving a good approximate solution will be quite daunting..
Hi Metallic,
thank you for your interest in this thread,
Would it be Possible to find the angle of thrust using the derivative of my proposed equation ?
it is possible to determine the original equation by substituting enough infinitesimally close points?
Yes it would be possible to find the angle of thrust by taking the derivative of your equation. But is your equation anywhere close to the real deal? :smile:
If it were true, then we would have:
let the gravity constant be on Earth = g
let the acceleration of the rocket = a
So [tex]y=tan\theta.x^{\frac{1}{k}}[/tex]
Actually, the derivative would be quite complicated. Only because [itex]\theta[/itex] is a variable and not a constant.
Just an idea:
If we remove all other variables including gravity for a second and watch the path of the rocket in its flight while providing thrust, assuming it's nose still dips towards the horizontal as its centre of gravity (even though gravity isn't present) balances out the rocket, then the fractional index power would be a good guess.
So its height above the ground at any time h, and displacement along the horizontal x is given by [tex]h=c.x^\frac{1}{k}[/tex] where c and k are constants
Then [tex]\frac{dh}{dx}=\frac{c}{k}.x^{\frac{1}{k}-1}[/tex]
But [tex]\frac{dh}{dx}[/tex] is the gradient and the direction the rocket is pointed at which is [tex]tan\theta[/tex]
So [tex]tan\theta=c.x^{\frac{1}{k}-1}[/tex]
Now another problem. Once we bring gravity back into this, the fractional index guess won't work because gravity will force the rocket to be pushed further down as the rocket straightens out. This wouldn't follow such a simple path.
Real life problems become big problems :-p maybe the physics section will help you out more.
thanks,
  • · Replies 39 ·
  • · Replies 20 ·
11K
13K
11K
