bob012345
- 1,127
Is ##p = \frac{m_f}{m_r}## mass of fuel over dry mass?Filip Larsen said:Instead of taking the time or burn rate limit of the rocket equation one can also consider that ejection of, say, half the total mass in one go will give the remaining mass (payload) same speed as the propellant, namely the ejection speed (##v_1 = 1## if we ejection speed to one). If now instead the same propellant is ejected as ##n## equal mass parts the total velocity ##v_n = \sum_{i=1}^n \frac{1}{2n-i}## quickly falls below 1 and has (as far as I can see) the rocket equation with mass factor 2 as limit, i.e. ##v_n = \ln(2)## for ##n \rightarrow \infty##. This seem like an "easy" argument for ejected all mass at once gives highest total velocity (i.e. no propellant is spend accelerating any other propellant). And this is actually the opposite conclusion as what the OP seeks.
Later: I can see why the above does not properly model rocket propulsion, because I have wrongly fixed the ejection speed relative to center of mass and not relative to the remaning mass ejecting the propellant. Correcting for that, keeping ##v_e## and using a total propellant ratio ##p## (where above text used ##p = 1/2##), I now get that ##v_n = \sum_{i=1}^n \frac{p}{n+1-p i} v_e## which starts much lower and now actually increase towards the rocket equation as ##n \rightarrow \infty## which is also what I would have expected and which supports the OP question.
I got ##\Large \frac{v_f}{v_e} = \sum\limits_{k=1}^n \Large\frac{1}{n(1 + \frac{m_r}{m_f}) -k}##
which for ##n = 1## gives the simple mass ratio and for ##n →∞## approaches the rocket equation from above.
