Rolling Cylinders across a grid of bars
The problem involves a cylinder being pulled across a grid of bars with a separation of length l, where the cylinder rolls without slipping. The objective is to find the terminal velocity of the cylinder while considering the dynamics of its motion and energy loss during collisions with the bars.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the relationship between work done by the pulling force and the energy lost during collisions with the bars. There are questions about the conservation of angular momentum and kinetic energy at the point of impact. Some participants attempt to visualize the setup and clarify the motion of the cylinder as it interacts with the bars.
The discussion is ongoing, with various interpretations of the motion and energy dynamics being explored. Some participants have offered insights into the conservation laws applicable during impacts, while others are seeking clarification on specific aspects of the problem setup and calculations.
There is a noted difficulty in visualizing the problem, and some participants have requested additional diagrams or figures to aid understanding. The assumptions regarding the size of the bars and the nature of the collisions are also under discussion.
Carbon123
A cylinder is placed on bars.The separation of each bar is l.The cylinder is then pulled with a force F through its center.Find the terminal velocity of the object.Assume l<<R and the ball rolls without slipping.
1/2 mv^2 +1/2 Iω^2 = kinetic energy
Work is F*distance
My thought is that when the work done by the force is equal to the energy loss due to the change of axis of rotation ,the velocity will be constant.
Thus,if its velocity before the collision with the new ridge is Vo then after the collision it will be V'.The distance it travels after every ridge is l/2.So the work is F*L/2.This work is equal to the kinetic energy loss,but I cannot figure out what V' is ? Can anyone give me advice or if my idea of this problem is correct ? Thanks in Advance !
I'm having a hard time visualizing the situation. Does this problem come with a figure that you could scan and Upload? Also, the thread title "Rolling Cylinders through Bar" is pretty confusing -- Can I change it for you to make it less confusing?
EDIT/ADD -- Thread title updated. :smile:
Cylinder Rolling in a Bar...
http://2.bp.blogspot.com/-9dtRWNy-_2s/Vol6CqB8DHI/AAAAAAAAHVo/BOX0lm92N2U/s1600/barrel+track+2016.png
Here's my guess at the setup:
There is a horizontal grid of parallel, equally spaced bars of negligible thickness, like a cattle grid.
The cylinder is being dragged across them, so it keeps rolling over one bar and crashing onto the next. The work done by the force at each interval is lost in the inelastic collision with the next bar.
Is that it?
Yes that is it.The cylinder is dragged on grids of round bars( negligible in size) with the axis of rotation being parallel to the bars.Sorry if the explanation is confusing;I have difficulty finding the word to describe it.
If the velocity when on top of a bar is v0, what will it be just before it reaches the low point?
When it hits the next bar, what is conserved?
On the point of contact,is the angular momentum conserved ? But there is a force creating torque around the point.For the velocity ,here is what i think.The cyllinder will rotate around the bar so kinetic energy will be 1/2 I ω2 where I is moment of inertia around point of contact. So the difference in total kinetic energy is F*l/2 ?(assuming the ball drops only a small amount) and use the relation v =ωr to find the speed in the bottom.
The impact on the next bar takes negligible time, so the gravitational force, the normal and frictional forces from the previous bar, and the force from the string contribute negligible angular momentum during it. The only force of interest during the impact is the collision with the new bar. You can eliminate that by taking moments about that point of contact.
ο=Iω with I being around the pont of contact.This equation doesn't really make sense considering the inertia is the same around the contact points,therefore the omega is constant (?)
The impact changes the direction of motion of the centre of the cylinder. Consider the angular momentum about the impact point as made of two components, the rotation of the cylinder about its centre, plus the moment of the linear momentum of the cylinder.
Just after impact, the linear motion is orthogonal to the line from impact point to centre of cylinder. Just before impact it is not.
By the way, it occurs to me it makes more sense to consider the interval from one impact to the next, rather than from the high point to an impact. This avoids having to think about gravity.
I am quite confused,sir.What do we need to know is he loss in energy after every collision right ? So what is the next step I should do ?
Suppose the cylinder is rotating at rate ω just before an impact. Let the two consecutive bars subtend an angle 2θ at the cylinder's centre.
Regard the cylinder's motion as the sum of the linear motion of its centre and a rotation ω about that centre.
What is the linear velocity of the cylinder's centre? What direction is it in? What is the angular momentum from that about the bar it is about to strike?
Before the collision ,The linear velocity of the cylinder should be perpendicular to the bar on the left.I imagine as if the cylinder rotates around an axis that is the bar,therefore the speed is or is this wrong ?.If i consider it as a normal cylinder motion then the cylinder will have V=wrcosθ,but I don't think that is the case.
Yes... is what?
That is one component of it. Which component? If the mass of the cylinder is m, what angular momentum does that velocity component give about the new bar?
haruspex said:
Yes... is what?
Oopa i thought I had typed it. What I meant to say was the speed will be ωR and the direction is perpendicular to the line connecting center of mass and left bar,with ω being rotation wrt to the bar.(Now that i think of it ,it seems incorrect )
After the collision only the horizontal component of the speed is conserved so wRcosΘ is conserved so the speed loss is WR-Wrcosθ ?(the angular momentum conservation would give Iω+MωRcosθRcosθ = I ω'+MRω'cosθRcosθ) but this would yield nothing (ithink). what part of the speed would be conserved after the collision ? Is it the horizontal component ,sir? (Sorry if I am a bit slow)
That is correct. Why do you doubt it?
The collision impulse will have a horizontal component. The only thing that is necessarily conserved is angular momentum about the impact point.
Angular momentum before the collision will be Iω+MVRcosΘ=Iω'+MvRcosΘ where v is total linear speed. What should i do next ?
Carbon123 said:
MVRcosΘ
Not quite. Look at how I defined θ in post #11.
Also, write v in terms of ω, and I in terms of m and r.
Why wpuld it be wrong ? Please point it out, sir
Draw a diagram. Label the bar it was just rolling on A, the bar it is about to hit B, the centre of the cylinder O.
I defined theta as half of the angle AOB.
Draw the velocity direction vector from O. This is normal to AO. For the angular momentum about B you want the component of the velocity that is normal to OB. What is the angle between those two normals?
Here is the image
Carbon123 said:
Here is the image
You are showing v cos(θ) as the horizontal component, which is correct, but not what is wanted. For the angular momentum about B we need the component normal to OB.
So that would mean Wrcos2Θ
Right.
So what is the total angular momentum about B just before impact?
If just after the impact it has angular velocity w' about B, what is its angular momentum in terms of that?
MωRcos2Θ×R is angular momentum around point B .angular momentum after is going to be Mω'R×R ?
That's only the angular momentum due to the linear velocity. Don't forget the rotation about the cylinder's centre.
Oh,then plus Iω on the left side and Iω' on the left
Yes. So what is the whole equation?
  • · Replies 40 ·
