Can a Rotating Coherent Laser Beam Create a Persistent Light Dot for Holography?
The discussion centers on the feasibility of creating a persistent light dot for holography by rotating a coherent laser beam at high angular frequencies. Participants explore the implications of rotating the beam about an axis normal to the laser, questioning whether this could yield a radiant glow due to persistence of vision. The conversation also touches on the potential effects of using excitation of the medium, such as two-photon excitation, to enhance the visual output. The consensus indicates that while a linear fall-off from the point of rotation is expected, alternative methods may yield different results.
  • Understanding of coherent laser beam properties
  • Knowledge of persistence of vision principles
  • Familiarity with laser scanning display technology
  • Basic concepts of two-photon excitation microscopy
  • Research the principles of laser beam rotation and its applications
  • Explore the mechanics of persistence of vision in visual displays
  • Investigate the use of two-photon excitation in holography
  • Study the design and functionality of scanning laser displays
Optical engineers, holography researchers, and anyone interested in advanced laser applications and visual perception technologies.
hackhard
if a coherent laser beam rotates about an axis at very high angular frequency
can a light dot with radiant glow (of short radius) be obtained due to persistence of vision ?
Science news on Phys.org
Rotate about which axis? Do you mean like with scanning laser displays?
http://www.covesion.com/assets/images/laser-display.jpg
rotates about axis normal to laser beam .
You mean there is only one point in space (filled with some scattering medium like air), where the beam always passes? You will get an approx. linear fall-off from that point. Maybe if instead of scattering you use some form of excitation of the medium, you might get different effects.
please explain
can this concept be employed in holography
  • · Replies 25 ·
  • · Replies 23 ·
  • · Replies 0 ·
