- 4,407
Yes if the water is at rest in the rotating frame, it has some angular momentum around the center of the bucket.John Mcrain said:You mean like this?
If we stop rotate G-room when bucket is at the wall, water in bucket will still spin some time. That is proof that water also rotate about itself during G-room rotation.
You can (but don't have to) decompose the inertial forces like that. But the effect of the circular translation is not a parabolid shape, because the inerial froce field from the centripetal acceleration is uniform. It's a choice of reference frame origin:John Mcrain said:Does it mean we must add together effects of water rotation(U shape) plus effects (parabolid shape ) of water circle around Groom pivot point, when G-room is rotate?
A) In the co-rotating frame with origin at the center of the room, you have the following inertial forces:
- Centrifugal force radially away from the room-center (due to rotation of the reference frame axes)
B) In the co-rotating frame with origin at the center of the bucket, you have the following inertial forces:
- Centrifugal force radially away from the bucket-center (due to rotation of the reference frame axes)
- Uniform inertial force parallel to the line connecting the room-center and the bucket-center (due to non-inertial translation of the frame origin)
The sum of the two fields in B must equal the centrifugal force in A. In both frames the water is at rest, so there are no Coriolis forces.
