Rotation: mass transfer and angular momentum conservation
4 replies · 2K views
Avi Nandi
a drum of mass M[itex]_{a}[/itex] and radius a rotates freely with initial angular velocity ω[itex]_{a}[/itex](0). A second drum with mass M[itex]_{b}[/itex] and radius b greater than b is mounted on the same axis and is at rest, although it is free to rotate. a thin layer of sand with mass M[itex]_{s}[/itex] is distributed on the inner surface of the smaller drum. At t=0 small perforations in the inner drum are opened. the sand starts to fly out at a constant rate λ and sticks to the outer drum. Find the subsequent angular velocities of the two drums ω[itex]_{a}[/itex] and ω[itex]_{b}[/itex]. Ignore the transit time of the sand.
torque on drum A = [itex]\frac{1}{2}[/itex](M[itex]_{a}[/itex] + M[itex]_{s}[/itex]- λt)a[itex]^{2}[/itex]dω[itex]_{a}[/itex]/dt + [itex]\frac{1}{2}[/itex]λa[itex]^{2}[/itex]ω[itex]_{a}[/itex](t)
torque on drum B = [itex]\frac{1}{2}[/itex](M[itex]_{b}[/itex]- λt)b[itex]^{2}[/itex]dω[itex]_{b}[/itex]/dt - [itex]\frac{1}{2}[/itex]λb[itex]^{2}[/itex]ω[itex]_{b}[/itex](t)
now applying angular momentum conservation on the system I got a relation between ω[itex]_{a}[/itex] and ω[itex]_{b}[/itex].
I don't think that the Torque equations are needed. all you need to do is to conserve the angular momentum.
but i can not find any more relations between ω[itex]_{a}[/itex] and ω[itex]_{b}[/itex].
That can't be enough. For any given distribution of sand between the drums there will be a continuum of solutions for the two angular velocities that give the same overall angular momentum.
Avi Nandi, I'm unconvinced by your expression for torque on the inner drum. If a cart is traveling along and some of the load on the cart falls off, what force does that exert on the cart?
thank you haruspex and darkxponent.
