Rotational/angular problem: the bike wheel with a valve stem
The discussion focuses on calculating the torque exerted by a bicycle wheel's valve stem, which is 34 cm from the rotation axis and positioned 32 degrees below the horizontal. The initial attempt used the formula torque = rFsin(theta) but yielded incorrect results. The correct approach involves using torque = rFcos(theta) after properly visualizing the force vector and its direction relative to the wheel's rotation. The final calculation resulted in a torque of 0.02825 N*m.
  • Understanding of torque and its calculation using the formula torque = rFsin(theta).
  • Knowledge of basic physics concepts such as force, mass, and gravitational acceleration.
  • Familiarity with vector representation and cross products in physics.
  • Ability to visualize forces acting on rotating bodies.
  • Study the concept of torque in rotational dynamics, focusing on the relationship between radius, force, and angle.
  • Learn about vector decomposition and how to apply it in physics problems involving forces and torques.
  • Explore the implications of using sine vs. cosine in torque calculations based on force direction.
  • Practice similar problems involving torque calculations in different contexts, such as pendulums or rotating machinery.
Students studying physics, particularly in mechanics, engineers working with rotational systems, and anyone interested in understanding torque calculations in real-world applications.
4t0mic
You have your bicycle upside-down for repairs. The front wheel is free to rotate and is perfectly balanced except for the 16 g valve stem. If the valve stem is 34 cm from the rotation axis and is located 32 degrees below the horizontal, what is the resulting torque about the wheel's axis? (torque = N*m)
torque = I(alpha)
torque = MR^2(alpha)
So I thought that torque = rFsin(theta) would be the most relevant since I think I know the radius, force, and the theta, giving me:
torque = r(mg)sin(theta)
torque = (.34cm)(0.016kg * 9.8m/s^2)(sin32)
= 0.02825 N*m
But this is wrong. What did I do wrong?
You did your cross product wrong.
Thanks for the reply. But I am using the right equation, right? So the F part in the equation is where I'm doing it wrong...
Ooh, so I took a break for a bit and I finally understand what you mean about the cross product. It all makes sense. I just had to redraw my diagram and draw the Force (mg) from the wheel but then draw the tangent line to the wheel where the Force is coming from. So it's torque = rFcos(theta).
  • · Replies 25 ·
  • · Replies 44 ·
