Deriving Rotational Energy Equation for Rigid Bodies
The discussion focuses on deriving the rotational energy equation for rigid bodies, specifically demonstrating that the energy of rotation can be expressed as E = ½Iω², where I is the moment of inertia. The moment of inertia is defined as I = ∫ dV ρ r², with r representing the distance from the rotation axis to the volume element dV and ρ as the density. The user successfully links linear and rotational motion by substituting v = ωr into the kinetic energy equation, ultimately confirming the relationship between rotational energy and moment of inertia.
  • Understanding of rotational dynamics and angular velocity
  • Familiarity with moment of inertia calculations
  • Knowledge of integration techniques in physics
  • Basic concepts of kinetic energy in mechanics
  • Study the derivation of the moment of inertia for various shapes
  • Learn about the parallel axis theorem in rotational dynamics
  • Explore applications of rotational energy in real-world systems
  • Investigate the relationship between torque and angular momentum
Students studying physics, particularly those focusing on mechanics and rotational dynamics, as well as educators seeking to clarify concepts related to energy and motion in rigid bodies.
Crosshash
Hello, I think I've got the right idea on how to perform this question but I just need a little bit of help.
Show that for a rigid body rotating with angular velocity \omega the energy of rotation may be written as:
E = \dfrac {1}{2}I\omega^{2}
where the moment of inertia of the body about the axis of rotation is given by:
I = \int dV \rho r^{2}
where r is the distance from the rotation axis to the volume element dV and \rho is the density of the object in that region
E = \dfrac {1}{2} mv^{2}
v = \omega r
I = \int r^{2} dm
I can firstly identify that
E = \dfrac {1}{2} mv^{2} which looks similar to the rotation energy equation.
I know that
v = \omega r
But what's confusing me is that usually, the moment of Inertia is represented as
I = \int r^{2} dm and I don't really know how to link the two.
Substiting angular velocity into the energy equation
E = \dfrac {1}{2} m(r\omega)^{2}
but where do I go now?
Thanks
So if you have a little volume dV at radius r, its mass is rho*dV, right? What is the kinetic energy of this little piece? For the total energy you should then sum (read: integrate) all these pieces.
Thanks for the reply CompuChip, sorry for this late reply. I took onboard what you said, perhaps you could verify my answer.
I have v = \omega r
dm = \rho dV
I = \int \dfrac {dm}{\rho} \rho r^{2}
I = \int dm r^{2}
I = r^{2} \int dm
I = r^{2}m
m = \dfrac {I}{r^{2}}
E = \dfrac {1}{2} m v^{2}
E = \dfrac {1}{2} m \omega^{2} r^{2}
E = \dfrac {1}{2} \dfrac {I}{r^{2}} \omega^{2} r^{2}
E = \dfrac {1}{2} I \omega^{2}
Is that the best way?
  • · Replies 17 ·
16K
  • · Replies 24 ·
