Rotational Equilibrium and Dynamics -
The discussion centers on calculating the initial and final rotational kinetic energy of a skater who changes his moment of inertia while spinning. The formula for rotational kinetic energy, KE = 1/2·I·ω², is confirmed as correct. The initial moment of inertia is given as 41 kg·m², and the final moment of inertia is 36 kg·m², with the angular speed remaining at 12.0 rad/s. Participants emphasize using the conservation of angular momentum to find the kinetic energy values. The conversation concludes with clarification on using the provided inertia values for calculations.
raconteur
Rotational Equilibrium and Dynamics - :)
I'm totally stumped!
A skater spins with an angular speed of 12.0 rad/s with his arms outstretched. He lowers his arms, decreasing his moment of inertia from 41 kg·m² to 36 kg·m²
Calculate his initial and final rotational kinetic energy.
Is the formula KE=1/2·I·ω² ?
ω=angular speed.. so ω=12.0 rad/s
so then how would i get I (inertia) ?
and how would i find out initial and final ?
i just need some help
yes
its given. read the question
Use conservation of Angular momentum.
hmm, i think i get it
so.. i use (plug in) 41 kg·m² to get my initial and 36 kg·m² to my my final?
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
