Rotational kinematics using energy
The discussion focuses on calculating the final velocity of a 45.0-cm diameter wheel made of thin rigid plastic with a linear mass density of 25.0 g/cm, released from a height of 52.0 m. The key equation used is the conservation of mechanical energy, represented as MEi = MEf, leading to the derived formula v^2 = (2*m*g*h) / (m + (I/R^2)). The moment of inertia (I) is calculated as I = mR^2 + 6/3 * mR^2, resulting in I = 0.235863 kg·m². The final velocity is determined to be approximately 15.96 m/s, although the user initially questioned this result.
  • Understanding of rotational kinematics and energy conservation principles
  • Familiarity with moment of inertia calculations for composite objects
  • Knowledge of basic physics equations involving gravitational potential energy
  • Ability to manipulate equations involving linear mass density and radius
  • Study the derivation of the moment of inertia for various shapes in rotational dynamics
  • Explore the effects of changing mass density and dimensions on rotational motion
  • Learn about energy conservation in different mechanical systems
  • Investigate the relationship between linear and angular velocity in rolling motion
Students studying physics, particularly those focusing on mechanics and rotational dynamics, as well as educators seeking to clarify concepts related to energy conservation and moment of inertia.
alco19357
A 45.0-cm diameter wheel, consisting of a rim and six spokes, is constructed from a thin rigid plastic material having a linear mass density of 25.0 g/cm. This wheel is released from rest at the top of a hill 52.0m high.
a.) How fast is it rolling when it reaches the bottom of the hill?
b.) How would your answer change if the linear mass density and the diameter of the wheel were each doubled?
MEi = MEf
\omega = V / R
mghi = .5m*v2 + .5I*(v2 / R2)
v2 = (2*mghi) / (m + (I/R2))
I = mR^2 + 6/3 *mR^2
= 3mR^2
v^2 = 2mgh / (m + (3mR^2 / R^2))
= .5 * ghi
I get v = 15.96
but that is wrong?
Nevermind. For those of you who are having trouble, figure I as a numerical number.
So I = m*R^2 + 6/3 * m*R^2
Note that the R is the radius of the wheel, hence, R is the same for both parts of the equation. However, m in the first part is the mass of the WHEEL (so you'll take the circumference of the rim and multiply it by the linear density) and m in the second part is the mass of each stoke (so you'll take one stoke's length and multiply it by the linear density).
You should get I=.235863
Then you have the equation
in both parts, the m is the mass of the total system (the 6 stokes and the rim, it should be like 6.909kg). The h is the initial height (52m) and the R is the radius of the rim. Take the square root and you'll get v.
For part 2, it won't change.
  • · Replies 25 ·
