Rotational Motion and Linear Speec
The discussion revolves around a problem in rotational motion, specifically involving a rubber ball rolling off a table and its linear speed as it falls. The problem includes elements of both linear and rotational dynamics, requiring an understanding of the relationship between linear speed and rotational speed.
  • Participants discuss converting revolutions to radians and the use of the equation v=rw to find linear speed. There are attempts to understand how to calculate rotational speed from the given distance and number of revolutions during the fall.
The discussion includes attempts to clarify the relationship between linear and rotational motion. Some participants have offered guidance on calculating time and understanding the conversion of revolutions to radians. There is an indication of progress as one participant reports figuring out their confusion.
Participants express confusion regarding the initial setup of the problem, particularly the transition from revolutions to linear speed and the implications of the falling distance. There is a mention of the need to consider gravitational acceleration in the calculations.
dukes
A rubber ball with a radius of .048 m rolls along the horizontal surface of a table with a constant linear speed v. When the ball rolls off the edge of the table, it falls 0.85 m to the floor below. If the ball completes 0.82 revolutions during its fall, what was its linear speed, v?
I know to find linear speed the equation v=rw must be used.
Revolutions are changed to radians so it's 5.15 radians
I tried to turn revolutions into radians and then use the equation T=2pi/w
and then did v=rw. I don't really know where to begin this problem since the problem has revolutions and not rpm. When i solved it like rpm it didn't work.please help me! I'm so confused!
Well, you know how to convert rotational speed to linear speed using the equation in step 2 - all you need is the rotational speed and the radius of the ball. You also know the radius. So the question is, how do you find the rotational speed?
You are given a distance the object falls (under acceleration from gravity), and you are given the number of rotations. Rotations / time is rotational speed. See if you can calculate the time and go from there.
so to find time can i just divide distance/acceleration and then take the square root?
Also when you say revolutions/ time = rotational speed I have to change revolutions to radians correct?
never mind i figured it out! thanks so much for your help!
  • · Replies 35 ·
  • · Replies 18 ·
