Rotational motion and tangential speed?
To determine the maximum speed of a 919 kg rollercoaster on a circular track with a diameter of 16.21 m without leaving the track, the balance of forces must be analyzed. A free-body diagram illustrates that the gravitational force must equal the required centripetal force at the highest point of the track. The centripetal force is dependent on the tangential velocity, which can be calculated using the formula F=ma. The discussion emphasizes that while gravity varies with the angle, it can be simplified for introductory physics problems. Understanding the relationship between gravitational force and centripetal acceleration is crucial for solving this problem.
yramos9
A 919 kg rollercoaster is about to go up a hill that acts as the top of a circle 16.21m in diameter. What is the fastest that car can move (in m/s) without leaving a track?
known:
mass: 919 kg
diameter: 16.21
radius: 8.105
Vt=r\omega
\omega=\theta/time
i have no idea how to work this out without knowing the time or speed or somekind of time measurement. Is there another way to solve this?
centrifugal force
force balance
free body diagram
huh??
Draw a free-body diagram of the cart with centrifugal force pulling it up and gravity pulling it down. The sum of the forces on the cart should be zero in the radial direction (since that's the direction for which you don't want motion). Centrifugal force should be a function of tangential velocity, which is the velocity in question.
What level of physics is this? Gravity would realistically be a function of the angle about the center of the circle and only be exactly g when the cart is exactly on the tip of the half-circle. But you could probably neglect this if it's an introductory physics course.
this is 11th grage physics pre-ap.. i don't think I've learned what youre trying to teach me.
When gravity can provide the centripetal acceleration required to keep the roller coaster on the track, the coaster doesn't fly off. Otherwise, it does. When does gravity exactly equal the required centripetal force? (Hint: F=ma)
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
