Rotational Motion around a Fixed Axis
The discussion revolves around the rotational motion of two identical doors, A and B, which rotate about different axes. Door A rotates about its left edge, while Door B rotates about its center, with the same force applied to both. The problem asks how long it takes for Door B to rotate through the same angle as Door A, given that Door A takes 3.00 seconds. Participants express confusion over which equations to use, particularly regarding angular velocity, torque, and moment of inertia, noting that the moment of inertia for Door B is half that of Door A. The main challenge lies in understanding the relationship between these factors and how they affect the rotation time of each door.
Ollie359
The drawing shows the top view of two doors. The doors are uniform and identical. Door A rotates about an axis through its left edge, and door B rotates about an axis through the center. The same force is applied perpendicular to each door at its right edge, and the force remains perpendicular as the door turns. Starting from rest, door A rotates through a certain angle in 3.00 s. How long does it take door B to rotate through the same angle?
what work have you done on the problem?
I haven't.. I have no idea where to start! :(
I've tried different equations. But there is an answer in the back of the book.. and everything that I try to do doesn't come out to be that answer. I'm kinda stumpped on what equation to use since there is only one number given in the problem...
It's a question about rotation ... relevant ideas are :
angular velocity, Torque, anglar acceleration, Moment of (rotational) Inertia, angular momentum.
Which are different for these doors? Different by what factor?
(double? half?)
its different by half right? since the axis is in the middle instead of outside. I got that but I'm not sure what that pertains too..
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
