Rotational Motion Speed at the top of the loop
To find the speed of a motorcycle at the top of a vertical loop with a radius of 12 m, where the normal force is one-fourth of the driver's weight, the relevant equations include F=ma and a=v²/r. The calculation involves setting the net force equal to the difference between the centripetal force and the weight of the driver. The derived equation leads to a speed of 9.4 m/s, which matches the correct answer choice. This solution highlights the importance of understanding forces in rotational motion.
physgrl
12. A motorcycle travels around a vertical 12 m radius loop. What is its speed at the top of the loop if the normal force exerted by the seat on the driver is equal to ¼ of his weight?
a. 7 m/s
b. 8.1 m/s
*c. 9.4 m/s
d. 15 m/s
e. 88 m/s
F=ma
W=mg
T=F-W
a=v2/r
I did (1/4)W=m(v2/r)-W and I got 12.1 m/s
I get the same answer as you.
