Runge-Lenz Vector: Calculating Magnitude & Direction
  • Thread starter Thread starter samjohnny
    Vector
The discussion revolves around the Runge-Lenz vector, specifically focusing on its magnitude and direction in the context of orbital mechanics. Participants are exploring the properties of this vector as a constant of motion and its relationship to the eccentricity vector in different types of orbits.
  • Participants discuss the differentiation of the Runge-Lenz vector to show it is a constant of motion. There is uncertainty about explicitly calculating its magnitude and direction, particularly in circular orbits. Some suggest using initial conditions and vector relationships to derive further insights.
The discussion is ongoing, with participants sharing their thoughts on the relationship between the Runge-Lenz vector and the motion of the object. Some guidance has been offered regarding the use of dot products and initial conditions, but multiple interpretations of how to approach the problem are being explored.
Participants note the necessity of knowing initial conditions for the particle's motion, which may influence the calculations of the Runge-Lenz vector. There is also mention of different types of orbits, such as circular and elliptical, which may affect the discussion.
samjohnny
Please find it attached.
For the first part of the question I managed to show that the vector is a constant of the motion by differentiating it with respect to time and showing that it yields a value of zero.
As for the second part where I need to calculate the magnitude and direction of the vector then I'm not sure how to go about doing that explicitly. I know that the way vector is defined is such that it is equivalent to the eccentricity vector and so for the circle part it would necessarily be equal to zero. But to show that explicitly I'm not to sure. Any ideas?
Hi,
First of all, notice that the Rung-Lenz Vector could be written by velocity of the particle, because momentum divided my mass is equal to velocity, and K is a constant. Obviously, it is necessary to know initial conditions of the particle, so assume that we know the initial distance and initial velocity, and therefore, the Runge-Lenz Vector (I show this with A). Let me show the particle position vector's with R. Now, calculate Dot Product of A and R in two different ways; in the first path, consider the A has its initial value, but in the second way, put its definition expression. Hence, by some calculation, you can find the R in terms of angle (from a specific axis.)
Kiarash said:
Hi,
Thank you for the reply. Would it not be the case that, by dotting the Runge Lenz vector with R, the resultant expression would describe motion of the object? I'm not clear on what relation this would have to finding the magnitude/direction of the vector in the case of circular, elliptical etc orbits.
  • · Replies 25 ·
