Running Electrum in Python from the CLI on Ubuntu 20
  • Topic: Python
  • Thread starter Thread starter jack action
    Python Running Ubuntu
2 replies · 2K views
Insights Author
I'm trying to run electrum (written in python) from the command line on Ubuntu 20. I have 2 similar computers. The first one has version 4.0.4 and once in the electrum folder, I type electrum (the name of the executable file) and it executes whatever command I ask for.
My problem is with my other computer - which has the latest version 4.0.9 - where, first odd problem, I have to type python3 electrum to get a response. I even changed the header of the file from #!/usr/bin/env python3 to #!/usr/bin/python3, still need to call python3 first (and the file is executable).
But the worst part is that it fails to run. I get this backtrace:
Code:
  File "electrum", line 39, in <module>
    import asyncio
  File "/usr/lib/python3.8/asyncio/__init__.py", line 8, in <module>
    from .base_events import *
  File "/usr/lib/python3.8/asyncio/base_events.py", line 18, in <module>
    import concurrent.futures
  File "/usr/lib/python3.8/concurrent/futures/__init__.py", line 8, in <module>
    from concurrent.futures._base import (FIRST_COMPLETED,
  File "/usr/lib/python3.8/concurrent/futures/_base.py", line 7, in <module>
    import logging
  File "/root/Electrum-4.0.9/electrum/logging.py", line 15, in <module>
    class LogFormatterForFiles(logging.Formatter):
AttributeError: partially initialized module 'logging' has no attribute 'Formatter' (most likely due to a circular import)
I know what happen, but I don't understand why. (I'm a newbie with python) In the electrum folder there is a 'logging.py' and the import logging is clearly referring to a file in the 'python3.8' folder, but it chooses the local one instead (hence the circular import problem). I don't know what to do with that (specifiying a folder?), especially since it works fine on the other machine.
I'm tired and I would gladly accept any help.
If the directory containing the electrum file is not on your PATH, the shell won't be able to find it, even if it is marked as executable.
And Python always looks there first (i.e., in the directory where the script being executed is located) for a file to import, before any other location. That's why that file is getting imported instead of the Python standard library one.
Since you are running an older version of electrum on the other machine, my guess would be that that older version does not have a logging.py file in the electrum directory, so the Python standard library logging module gets imported.
