Sally's Goal-Shooting - Binomial Distribution Q&A
The discussion revolves around a problem involving binomial distribution, specifically focusing on the probability of a goal shooter, Sally, successfully scoring goals in a series of attempts. The problem presents a scenario where the probability of success is given, and participants are tasked with calculating conditional probabilities based on specific outcomes of her attempts.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the interpretation of the probability equations related to successes in trials, questioning the definitions of events and the implications of conditional probabilities. There is an exploration of whether the probability calculations reflect the intended scenario of successes occurring in specific trials versus any trials.
Several participants have provided insights and corrections regarding the initial calculations and interpretations of the problem. There is recognition of the need for clarity in defining events and the relationships between them. The discussion is ongoing, with participants offering different perspectives on the correct approach to the problem.
Participants note the importance of distinguishing between the probability of achieving a specific number of successes and the order in which those successes occur. There is also mention of the intersection of events and how it affects the calculations, indicating a complexity in the problem that requires careful consideration.
psyclone
Hello all,
I just have a question which covers binomial distribution.
Sally is a goal shooter. Assume each attempt at scoring a goal is independent, in the long term her scoring rate has been shown as 80% (i.e. 80% success rate).
Question:
What's the probability, (correct to 3 decimal places) that her first 4 attempts at scoring a goal are successful, given that exactly 6 of her first 8 attempts are successful?
I've solved the problem the following way.
X~ Bi(8,0.8)
Pr(X=6) = 0.8^6*0.2^2 = 0.0105
Pr(X=4) = 0.8^4*0.2^4 = 0.0007
Pr(X=4 | X=6) = Pr(X=4 & X=6) = Pr(X=4) = 0.0007 = 0.067
------------------- ---------- --------- <--------divided signs
Pr(X=6) Pr(X=6) 0.0105
Note:{'&' means Intersection}, the answer given = 0.214. Is that correct?
I would like your thoughts.
Note: The previous two parts of the same question are (where the above is part iii):
(i) chance of getting 8 out of 8 shoots as goals.
(ii) change of getting exactly 6 out of 8 shoots as goals.
ref: MathsQuest(Yr-12)
Need the reasoning.
##p^n(1-p)^{N-n}## is the probability of n successes out of N trials.
It is not the probability that those n successes are the first n of them.
The probability P(X=6) you gave is the probability that any six are successes right?
If I read you correctly:
The probability P(X=4) you gave is the probability that any four of the trials are successes.
Pr(X=4 | X=6) is zero, because if X=6 it is never equal to 4.
Some food for thought: Does this part of the question even require knowing what Sally's probability of scoring each individual goal is?
Umm.. backwards?
##p^n(1-p)^{N-n}## is the probability of n successes out of N trials, and those being the first n.
##^NC_np^n(1-p)^{N-n}## is the probability of n successes out of N trials, those being any n.
@haruspex:
I picked the right issue but got it backwards - thanks.
<annoyed with self>
Advise to OP would be to be more careful about defining events.
Off the wording in post #1,
It looks like X is the number of trials that are successes
So X=x would be the event that exactly x trials were successes.
P(X=x) equation given was for the event that a particular x trials were a success.
P(X=x|X=y) equation... was for different X again?
By the first definition of X: P(X=x|X=y)=0 unless x=y - so that's not what is intended!
How about:
X is the event that the 1st n out of N trials are successes - the remaining N-n trials being anything.
Y is the event that any m out of the N trials are successes
X[itex]\small\cap[/itex]Y would be the event that there are m successes in N trials, in which the 1st n trials are successes.
... or something.
sorry for not getting back sooner. Thanks for responses,
To both of the above comments.
Correct. The intersection is equal to 0.
If we consider the problem as a tree diagram, there are 6 branchs of X=6 given the first 4 shots are successfull.
and given;
Pr(x=6) = 0.2936 (exactly 6 isn't the same as only 6, my bad).
Therefore:
(6*0.8^6*.2^2)/0.2936 = 0.214
and given;
Therefore:
That's the right answer.
The easiest way is to to turn it into: pick 6 objects from 8 in a line; what's the probability you pick the first 4? A: 4C4*4C2/8C6
