boboYO
- 106
Hi, I need some hints for the proof of the sard theorem in 1 dimension:
Prove that the set of critical values (f(x) where f'(x)=0) of continuously differentiable f:[a,b]->R has measure 0.My attempt:Fix \varepsilon, Let Crit(f) be the set of critical points of f. We want to show that f(Crit(f)) has measure 0.
Let C_k be the set of all x in Crit(f) such that |x-y|<\frac{1}{k} \implies |fx-fy|<\varepsilon|x-y|.
Clearly \bigcup_{k\in\mathbb{N}} C_k \supset \mathrm{Crit}(f), so it suffices to show that f\left(\bigcup_{k\in\mathbb{N}} C_k \right) has measure 0.
For any C_k, evenly split [a,b] into intervals I_1,\dots,I_n such that \frac{b-a}{n}<\frac{1}{k}.For each I_i, if there is a point of C_k in it, say x, then
|fx-fy|<\varepsilon|x-y| for all y in I_i.
Thus if I_i contains a point of C_k, then f(I_i) is contained in a open interval of at most 2w \varepsilon where w is the width of the interval.
Thus f(C_k) is contained in an open set of length at most 2w\varepsilon n =2(b-a) \varepsilon=K\varepsilon.
Since each f(C_k) has measure bounded above by K \varepsilon, and C_{k}\subset C_{k+1} for all k, then
\bigcup_{k\in\mathbb{N}} f(C_k) = f\left(\bigcup_{k\in\mathbb{N}} C_k \right) is also bounded above by K\varepsilon. Since \varepsilon was arbitrary we are done.
I am not completely convinced because I did not use the hypothesis that the derivative is continuous. Did I make a mistake? Is there a simpler way do this?
