Satellites Orbits and Energy Problem
7 replies · 5K views
i_hate_math
Two small spaceships, each with mass m = 2000 kg, are in the circular Earth orbit of the figure, at an altitude h of 440 km. Igor, the commander of one of the ships, arrives at any fixed point in the orbit 81.0 s ahead of Picard, the commander of the other ship. What are the (a) period T0 and (b) speed v0 of the ships? At point P in the figure, Picard fires an instantaneous burst in the forward direction, reducing his ship's speed by 2.00%. After this burst, he follows the elliptical orbit shown dashed in the figure. What are the (c) kinetic energy and (d) potential energy of his ship immediately after the burst? In Picard’s new elliptical orbit, what are (e) the total energy E, (f) the semimajor axis a, and (g) the orbital period T? (h) How much earlier than Igor will Picard return to P?
kepler's 3rd law: T^2=4*(π^2)*(r^3)/(GM)
Newton's law: F=GMm/R^2
Centripetal Force: F=mv^2/R
1st Escape Speed= v=sqrt(GM/R)
KE=0.5mv^2=GMm/2R ------- by substitute v into the equation
GPE=-GMm/R
E=KE+GPE=-KE
where M=5.972*10^24 kg and m=2000kg
For (a), I used keeper's law T^2=4*(π^2)*(r^3)/(GM) and took the sqrt of RHS, got T=91.88s
I got this one wrong
b) i used mv^2/R=GMm/R^2
and got the expression of v=sqrt(GM/R) ----- or just take the escape speed
v=3.01*10^4 again WRONG
c)KE=0.5m(v')^2=8.69*10^11 ----- where v'=0.98v
again this is WRONG solution
d)GPE=-2KE or GPE=-GMm/R
sub in values got GPE=-1.74*10^12
e)E=KE+GPE=-KE=-8.69*10^11
now the rest depends on the correct solutions of previous ones, I wouldn't bother typing in the rest of my attempt. Please enlighten me with your genius minds
This is not escape speed. It is orbital speed.
GPE=-GMm/R
E=KE+GPE=-KE
It's not clear from your calculations what number you are using for R.
I should say so. The period for objects in low Earth orbit is typically on the order of 90 minutes, rather than 90 seconds.
Again, not the escape speed - it's the orbital speed. There's a difference. What value are you using for R?
It's not clear from your calculations what number you are using for R.I should say so. The period for objects in low Earth orbit is typically on the order of 90 minutes, rather than 90 seconds.
I used R=440km=4400000m for R but I've now realized that R should be the radius of the Earth plus altitude that is R=6371+440=6811km=6811000m
Was my expression for orbital speed correct? apart from my false understanding of escape speed?
Also I have reworked my solution with the new R, I got 5.60*10^3 sec for T, which is close to the 90min you mentioned
Yes, your formula is correct for a circular orbit.
The equation GPE=-2KE should be replaced with GPE=-GMm/R since KE in this case is not conserved
@i_hate_math: I see that this thread has been marked solved. Has it really been solved to your satisfaction?
Yes @SteamKing has been very helpful
