Save Output of Python Program to TXT File: Tips & Tricks
  • Context: Python
  • Thread starter Thread starter mr.me
    File Output Python
3 replies · 4K views
mr.me
This isn't exactly part of my homework but I wanted to know how I could save the output of this program to txt file?
The program was my homework and it was to allow the user to enter the starting values for a multiplication tables columns and rows and print a 10x10table
I did it like so..
Code:
print "To create a '10x10' multiplication table: "
row = int(raw_input("Enter the first row number: "   ))
col = int(raw_input("Enter the frist column number: "))
lastRow = row + 10                          # These lines assign  the value  of the variables
firstRow=col
lastCol = col + 10
print "   ",
while (col<lastCol):                # loop from col to col + 10
    print "%3d" % col,              #each iteration prints the column header value.
    col+=1
print "\n","-"*50,
col=firstRow                        #reset col values
#end loop
print  #moves to the next line
while (row < lastRow):                      #This line creates the conditions in which both loops operate
    print row,"|",                          #Prints a header for each row
    while(col < lastCol):                   #This line creates the conditions for the inner loop
        print "%3d" %(col * row),
        col +=1
    col=firstRow                            #This line  updates the value for which "col"
    row +=1                                  #This line updates the value for "row"
    print
Is there a way I could save the printed values to a file?
mr.me, I will add that your code is very "un-Pythonic." It does not use any of the nifty features that make Python easier to use than other languages. Here's a more elegant version that uses implicit looping constructs:
Code:
firstRow = int(raw_input("Enter the first row number: "   ))
firstCol = int(raw_input("Enter the frist column number: "))
for row in range(firstRow, firstRow+10):
    cols = range(firstCol, firstCol+10)
    values = [ "%3d" % (row * col) for col in cols ]
    print "|".join(values), "\n", "-"*40
- Warren
You can run your program from the command line, something like this:
python myprog.py
Using the operating system, instead of modifying your program in any way, you can save a program's normal output to a file like this:
python myprog.py > myresults.txt
and the output will be saved on a file by that name in your current directory.
