Scaling up the nucleus to the size of a pin.
The discussion revolves around the scaling of atomic and nuclear sizes, specifically comparing the size of a nucleus to the tip of a pin. The original poster attempts to determine the size of an atom based on this scaling, questioning the relationship between the sizes of the nucleus and the atom when scaled up significantly.
  • Participants explore the scaling factor and its implications for the size of an atom, questioning whether the figures provided refer to radius or diameter. There is discussion about the approximation of sizes and the concept of "order" in measurements.
Participants are engaged in clarifying assumptions about the measurements and discussing the implications of approximations in size. Some guidance has been offered regarding the interpretation of "order" in the context of size, but there is no explicit consensus on the details of the calculations or assumptions.
There is uncertainty regarding whether the sizes mentioned in the problem statement refer to diameters or radii, which affects the interpretation of the scaling. The original poster also references a textbook for comparison, indicating potential discrepancies in understanding the problem setup.
takando12
If the size of the nucleus ( in the range of 10-15m to 10-14m) is scaled up to the tip of a sharp pin, what roughly is the size of an atom ? Assume the tip of the pin to be in the range 10-5m to 10-4m
It's scaled up by a factor of 1010 i.e from 10-15m to 10-5m. And we also know that an atom's diameter is of the range 10-10 m, and so 10-10*1010 is 1 m. So if the nucleus is blown up to the size of a pin's tip, the size of the atom will be 1m right?
My textbook however says " Thus the nucleus of an atom is as small as the tip of a a sharp pin placed at the center of a sphere of radius 1 m. How is this ? The diameter of the sphere should be 1 m right? Where am i wrong in my logic?
Not necessarily a fallacy. You are asked for the "order" of the size, not the "exact" size. What this means that as long as you have approximately the right figure you're OK and is a useful check. You may have made an error mathematically or otherwise and calculated this as a kilometre, or a milimetre, for instance and this is what the calculation is designed to catch
I don't understand. Is the radius of the sphere 1 m or not? I don't see where the calculation error is.please help.
No error. It's approximately 1 metre, as opposed to 1 kilometre, or 1 millimetre.
ok so if I hadn't seen the answer in my textbook and concluded that the radius of the sphere is 0.5 m , the answer is still fine right?
I would think so, but just rereading the question, are you assuming that the figures given are radius, or diameter for both figures (minor point)
Diameter is what I assumed. I also checked for the diameter of an atom and it's indeed in the order of 10-10m and the diameter of the nucleus is 10-15m as well. So do they mean radius when they say "size" in the question? They got it wrong?
The "order" of something is an approximation. If given correct data you calculated the time it takes Usain Bolt to run 100m to be 0.1 seconds, 1 second, 10 seconds, 100 seconds, or 1000 seconds which is most likely to be correct?
But if you're taking both figures as diameter, where has the 0.5 come in?
If we take both as diameters, then the 1 m I get after doing the multiplication must also be the diameter of the sphere with the pin in the middle right? And so in that case the radius must be 0.5m?
To state things mor bluntly: There is no one number which is a "correct" answer here. Atoms and nuclei come in many different sizes depending on the atomic number. As such you simply cannot give a precise value and bickering about 0.5 m vs 1 m is utterly pointless. Just as iff I ask you what the size of a boat is, you will not be able to answer 5.3 m. There are boats whicha are both much bigger and much smaller than this and thhe answer "of the order of 10 m" would be about as good as you could do.
So conclusion, I just say that it'll be in the order of 1 m. Period.
Yes, a factor of two is irrelevant when talking about orders of magnitude.
Edit: You might view order of magnitude computations as "what would be a good standard measure for x?"
Yes that makes sense, thank you all for the help.
38K
10K
10K
