Schwartz inequality proof over complex
6 replies · 4K views · last reply
jfy4
Consider any two vectors, [itex]|a\rangle[/itex] and [itex]|b\rangle[/itex]. Prove the Schwartz inequality
[tex] |\langle a|b \rangle |^2 \leq \langle a|a \rangle \langle b|b \rangle[/tex]
a basic understanding of vector calculus over [itex]\mathbb{C}[/itex]...
I wanted to do this proof almost the same way I do it over [itex]\mathbb{R}[/itex], except I'm not sure if I can follow through with the normal quadratic part...
I start with [itex]|\psi\rangle =|a\rangle + c |b\rangle[/itex] and using the fact that [itex]\langle\psi | \psi \rangle \geq 0[/itex] I get
[tex] 0\leq \langle \psi | \psi \rangle = \langle a|a \rangle + c\langle a|b\rangle + c^{\ast}\langle b|a\rangle + |c|^2\langle b|b\rangle[/tex]
which can be written
[tex] 0\leq \langle a|a\rangle + 2\Re[c\langle a|b\rangle ] +|c|^2\langle b|b\rangle[/tex]
So I'm wondering if I can consider this quadratic in [itex]c[/itex] and claim that
[tex] (2|\langle a|b\rangle |)^2-4\langle a|a\rangle \langle b|b\rangle \leq 0[/tex]
Any help would be appreciated, Thanks.
so for the real case
[tex]0\leq \langle a|a\rangle + 2\Re[c\langle a|b\rangle ] +|c|^2\langle b|b\rangle[/tex]
becomes
[tex]0\leq \langle a|a\rangle + c\langle a|b\rangle +c^2\langle b|b\rangle[/tex]
however for the complex case, that simplification does not occur. so I'm not convinced you can treat the quadratic the same as both the complex parts of c & <a|b> will cause complication - that said I'm not that familiar with this method...
The way I've seen that works for a general inner product space is to write |b> in as a summation of components perpendicular and parallel to |a> and prove it direct form there
[tex]|b\rangle = \langle a|b \rangle|a \rangle + |z\rangle[/tex]
Why do you think c must be complex? All the inner products you are using result in real numbers.
as the vectors are arbitrary <a|b> may be complex
now unless a constraint is put on c, then I would assume it can also be complex
now it is true that all the terms in the following expression are real, otherwise the inequality would not make sense
[tex]0 \leq \langle a|a\rangle + 2\Re[c\langle a|b\rangle ] +|c|^2\langle b|b\rangle[/tex]
now say we set c to be from the reals, then the inequality becomes
[tex]0 \leq \langle a|a\rangle + 2c\Re[\langle a|b\rangle ] +|c|^2\langle b|b\rangle[/tex]
this is a real quadratic in c, though I'm not sure how the part about Re{<a|b>} could be massaged into the required form?
If all else fails, split things into real and imaginary parts.
I think I got it, let
[tex] |\psi\rangle = |b\rangle - \frac{ \langle a|b\rangle }{\langle a|a\rangle }|a\rangle[/tex]
then
[tex] \begin{align}<br /> 0\leq \langle \psi|\psi\rangle &= \left( \langle b|-\frac{\langle b|a\rangle}{\langle a|a\rangle}\langle a| \right) \left( |b\rangle -\frac{\langle a|b\rangle}{\langle a|a\rangle}|a\rangle \right) \\<br /> &=\langle b|b\rangle - \frac{\langle a|b\rangle \langle b|a\rangle}{\langle a|a\rangle}<br /> \end{align}[/tex]
and the result clearly follows.
How does this look?
yep that's looking good to me
its worth noting the equality holds when |a> and |b> are parallel
