Schwarzschild spacetime proper time to fall radially inward
The discussion centers on calculating proper time in Schwarzschild spacetime when falling radially inward. The method involves setting specific values for the radial coordinate, R and 2GM, and integrating proper time over these values. However, the consensus is that direct substitution of the parameterization into the proper time equation is sufficient due to the invariance of the Lagrangian under reparameterization. Integration is unnecessary in this context as the parameterization already provides the required information.
  • Understanding of Schwarzschild spacetime and its properties
  • Familiarity with proper time calculations in general relativity
  • Knowledge of Lagrangian mechanics and its invariance under reparameterization
  • Basic proficiency in calculus, particularly integration techniques
  • Study the derivation of proper time in Schwarzschild spacetime
  • Learn about geodesics in general relativity and their significance
  • Explore Lagrangian mechanics and its applications in physics
  • Investigate the implications of reparameterization invariance in theoretical physics
Students and researchers in theoretical physics, particularly those focusing on general relativity, as well as anyone interested in the mathematical aspects of spacetime and proper time calculations.
binbagsss
Question attached
My method was going to be:
set ##r=R## and solve for ##n(R)##
set ##r=2GM## and solve for ##n(2GM)##
I was then going to integrate proper time ##s## over these values of ##r##:
##\int\limits^{n=cos^{-1}(\frac{4GM}{R}-1)}_{n=cos^{-1}(1)=0} s(n) dn ###
whereas the solution, all you have to do is plug in these values ##n(r)## and ##n(2GM)## into ##s=s(n)##, equation (2).
Is it wrong to integrate or would I get the same answer?
Is the reason that you can plug in and don't need to integrate due to the fact that the lagrangian, is invariant under reparameterisation, or does it have nothing to do with this??:
i.e:
##s=\sqrt{L}=\sqrt{g_{uv}\frac{dx^u}{dn}\frac{dx^v}{dn}} dn##, ##n## the parameter
see above
see above[/B]
I think it's simpler than that. You are given a parameterisation for ##s## in terms of ##\eta##. So, if you know the start and end values of ##\eta##, you can plug these in and get the start and end proper times.
If you were given ##ds##, then you would have to integrate that to get ##s(\eta)##, but that has already been done for you.
There's no more to it than that.
Re the metric, the fact that the parameterisation represents a geodesic is all you need to know (although even that doesn't really matter). You might want to check that it's a valid geodesic, but it looks like the question is giving you that as well.
  • · Replies 45 ·
  • · Replies 45 ·
  • · Replies 31 ·
  • · Replies 30 ·
