Science fair physics Investigation
The discussion centers around an experimental research project focused on determining the thermoelectric characteristics in the ambient environment of Qatar, particularly using thermoelectric generators. Participants explore the feasibility and implications of this investigation in the context of local environmental conditions.
  • Experimental/applied
  • One participant expresses interest in investigating the use of thermoelectric generators in Qatar's ambient environment, specifically using peltier tiles.
  • Another participant requests clarification on the specifics of the investigation, indicating a need for more detail on the research approach.
  • There is a suggestion that the effectiveness of thermoelectric generators may depend on the specific parameters of the investigation.
  • A participant proposes constructing a thermoelectric generator to test its performance under local weather conditions and to evaluate its viability as an alternative energy source for Qatar.
  • Concerns are raised about Qatar's reliance on oil for electricity generation, which may influence the relevance of thermoelectric solutions.
  • Another participant recommends investigating the properties of thermoelectric generators and their suitability for various applications, noting that they have advantages and disadvantages depending on the context.
Participants have not reached a consensus on the specifics of the investigation or the potential effectiveness of thermoelectric generators in Qatar. Multiple viewpoints regarding the feasibility and appropriateness of thermoelectricity as an alternative energy source remain present.
Participants have not fully defined the parameters of the investigation, and there are unresolved questions about the specific conditions under which thermoelectric generators would be evaluated.
Paulene Gueco
Hi, guys! So my school has a science fair coming up, and I've decided to do an experimental research on this topic:
Determination of thermoelectric characteristics in the ambient environment of Qatar.
I'll be using peltier tiles...?
I live in Doha, Qatar. Thoughts?
Science news on Phys.org
Can you elaborate a little on what you want to do?
Uhm, I haven't exactly figured out the details yet. But I thought that it'd be interesting to know if whether or not the use of thermoelectric generators would be an ideal thing.
That again is dependent on what specifically you are trying to investigate.
Well, what were your thoughts on how you might go about finding this out?
I was thinking of constructing my own thermoelectric generator and test it on the weather conditions here in Qatar. And afterwards, based on whatever results I get, conclude on whether or not the use of thermoelectricity is an appropriate alternative for Qatar?
I mean, since Qatar is rich in oil, electricity is mainly generated from it.
That sounds fine. I'd also recommend an investigation into the properties of thermoelectric generators and where they are most useful. As one of several different types of heat engines, thermoelectric generators have their pros and cons and are better suited for certain applications and less suited for others.
  • · Replies 21 ·
  • · Replies 17 ·
