Is the Scrambler Function in JESD204B Part of the Data Link Layer?
  • Thread starter Thread starter senmeis
    Function
The scrambler function in JESD204B is debated regarding its layer classification, with opinions divided between the data link layer and the physical layer. Some argue that scrambling occurs before frame alignment, placing it in the data link layer, while others assert it belongs to the physical layer, which handles bit and byte transmission. The discussion highlights that JESD204B's optional scrambling is intended for electromagnetic compliance and to prevent DC component issues in the transmission system. Additionally, it is noted that JESD204B does not fully conform to the OSI layer model due to its unique specifications. Ultimately, the classification of the scrambler function remains a complex topic within the context of JESD204B standards.
senmeis
Hi,
in some standards such as JESD204B or DVB-S2 a so called scrambler function is defined. As far as I understand this scrambler is a means of spreading spectrum but in data link layer. Is it correct?
Senmeis
I think it will prevent a series of zeros creating a DC component, which the transmission system cannot handle and which wil make clock extraction a problem. The data stream might be disconnected during maintenance, say.
Actually tech99 OP is correct. JESD204B has 8b-10b coding in the standard for DC balance. The optional scrambling is for EM compliance.
No. It is in the physical layer. The data link layer deals with bits, bytes and frames.
This may be down into the weeds (and not sure if anyone is following this thread) but OP is actually correct. In JESD204B the scrambler is in the link layer as scrambling happens before frame alignment (so we are dealing with bits, bytes, and frames here). See this discussion by Analog Devices:
https://www.analog.com/en/technical-articles/understanding-layers-in-jesd204b-specification.html
Likes anorlunda
Then JESD204B does not conform to the OSI layer model. From Wikipedia (https://en.wikipedia.org/wiki/Data_link_layer):
The services that the data link layer provides are:
Thread 'I thought it was only Amazon that sold unsafe junk'
I grabbed an under cabinet LED light today at a big box store. Nothing special. 18 inches in length and made to plug several lights together. Here is a pic of the power cord: The drawing on the box led me to believe that it would accept a standard IEC cord which surprised me. But it's a variation of it. I didn't try it, but I would assume you could plug a standard IEC cord into this and have a double male cord AKA suicide cord. And to boot, it's likely going to reverse the hot and...
