kev said:
Thanks Mute and HallsOf Ivy.
Not being very mathematically gifted, it will take me a while to absorb all you have said. I think I have gathered enough, that I now realize that trying to take the derivative with respect to x of ax^2 +bx +c = 0 was not a good choice of example.
To try and be more specific. This is from the other thread:
Although Starthaus does not make it clear here, it is clear in his later comments that he is claiming that in this particular case when espen imposes dr/dt=0 that it follows that d^2r/dt^2 must also be zero. Espen and myself disagree, but Starthaus claims to have superior calculus skills, so we can not simply ignore his claims. In this specific example is Starthaus right in his claim? I thought the best place to ask would be in this subforum frequented by calculus specialists. I think I should make it clear that from the context of the other thread that espen is talking about dr/dt= at some instant t, without making any assumption about dr/dt=0 for all t. In other words, espen is making the claim that at the instant in the particles trajectory when dr/dt=0 (at the apogee) the acceleration of the particle is:
\frac{\text{d}^2r}{\text{d}\tau^2} = -c^2\left(\frac{ r_s}{2r^2}-\frac{r_s^2}{2r^3}\right)\left(\frac{\text{d}t}{\t ext{d}\tau}\right)^2
(and of course espen's equation is only valid at the apogee) while starhaus is making the claim that at the apogee, the acceleration is:
\frac{\text{d}^2r}{\text{d}\tau^2} = 0
Starhaus is referring to the fact that if the
function \frac{dr}{dt} is identically zero for all time then the
function \frac{d^2r}{dt^2}(t) is identically zero for all time. This is true.
It can also be true that if the
value of the function \frac{dr}{dt}(t) at some time t = T is zero while the
value of the function \frac{d^2r}{dt^2}(t) is not zero: \frac{dr}{dt}(T) = 0, \frac{d^2r}{dt^2}(T) \neq 0.
The problem stated that at t = 0, the value of dr/dt is zero. So, if the differential equation were
\frac{d^2r}{dt}(t) + A\frac{dr}{dt}(t) + B = 0
then this equation is true for all time t and
this is the differential equation that must be solved. True, you could look at this at time t = 0, noting that dr/dt(t=0) = 0, which tells you
\frac{d^2r}{dt}(t=0) + B = 0,
i.e., the intial value of the acceleration is -B. However,
this is not a differential equation. This equation only tells you the value of the acceleration at time t=0. It tells you nothing else. Interpreting this equation as a differential equation is nonsense because it's not a differential equation. This seems to be the problem in the other thread - it sounds like someone over there plugged the initial condition into the differential equation and then solved the resulting equation as if it were a differential equation, which it is not.
I think I meant to say you can take the derivative of a x'(t) + b x(t) + c = 0. Does that make more sense?
Yes, you can take a derivative of that equation with respect to t because it hold for all t. However, note that you could not take a variational derivative that equation with respect to x(t) because that equation only holds for the function that is the solution of that differential equation. In the other thread you had written something like
\mathcal L[x(t)] = \frac{1}{2} \dot{x}(t)^2 - \frac{1}{2}kx(t)^2 = 0
You then varied the lagrangian with respect to x and claimed you got the equation of motion for x(t), and starhaus told you it was incorrect. The reason it is incorrect is that saying L = 0 (or a constant)
fixes what x(t) is. It demands that whatever x(t) is it has to satisfy 0 = \frac{1}{2} \dot{x}(t)^2 - \frac{1}{2}kx(t)^2. You can take a derivative of this expression with respect to t and it will still hold because it holds for all t, but you couldn't, for example, take a variational derivative with respect to x(t) because it doesn't hold for all x(t). This is analogous to taking a derivative (with respect to x) of the relation 0 = ax^2 + bx + c versus taking a derivative of the function f(x) = ax^2 + bx + c.
When we vary a Lagrangian, it's because we're varying the integral over it, the action. The action is a functional of the function x(t) - that is, we give the action some function x(t), and the functional spits out a number. Different x(t) inputs will give different numbers output. So, we can vary the
action with respect to x(t) because it is a functional of x(t), just as we can differentiate a function of x with respect to x. However, we can't vary the Euler Lagrange equations because they are just relations which define the
specific function x(t) which extremizes the action, just as we can't take a derivative with respect to x of a quadratic equation because a quadratic equation is just a relation that defines the value x which solves that equation.
I hope this makes sense...
