Second order differential equation via substitution
The discussion revolves around solving a second-order differential equation of the form x'' + ω²x = 0 through substitution methods. The original poster attempts to substitute p = dx/dt and manipulate the resulting equations, leading to a series of transformations and integrals.
  • Mixed
  • Participants explore various substitutions and transformations, including the use of separable first-order ODEs and trigonometric substitutions. Some express confusion over the necessity of multiple substitutions and the handling of constants in their equations.
There is an ongoing exploration of different approaches to the problem, with participants providing hints and questioning each other's reasoning. Some participants express uncertainty about their progress and the correctness of their methods, while others offer clarifications and corrections.
Participants note issues such as carelessness in calculations and the challenge of recalling methods after a period of inactivity. The discussion reflects a learning environment where assumptions and definitions are being questioned, and various interpretations of the problem are being considered.
bitrex
Substitute [tex]p = \frac{dx}{dt}[/tex] to solve [tex]x\prime\prime + \omega^2x = 0[/tex]
[tex]\frac{dp}{dx} = v + x\frac{dv}{dx}[/tex]
[tex]v = \frac{p}{x}[/tex]
[tex]p = \frac{dx}{dt}, \frac{dp}{dt} = \frac{d^2x}{dt^2}[/tex]
[tex]\frac{dp}{dt} = \frac{dp}{dx}\frac{dx}{dt} = \frac{dp}{dx}p[/tex]
[tex]\frac{dp}{dx} + \frac{\omega^2x}{p} = 0[/tex]
[tex]v + x\frac{dv}{dx} = \frac{-\omega^2}{v}[/tex]
[tex]\frac{-v}{\omega^2 + v^2}dv = \frac{1}{x} dx[/tex]
[tex]\frac{-1}{2}ln(\omega^2 + v^2) = ln|x| + C[/tex]
[tex]\frac{1}{\sqrt{\omega^2 + v^2}} = x + C[/tex]
I get tripped up here and I'm not sure how to go forward, with regards to all the various substitutions I've made! I see the beginnings of an integral involving trigonometric substitution, so I hope I may be on the right track. A hint would be much appreciated.
I don't understand why you are making a second substitution. You have a separable 1st order ODE for [itex]p(x)[/itex]:
Just solve it.
:smile: :cry: Wow, so I do. That's what I get for doing this when I'm tired!
To finish up:
[tex]p dp = -\omega^2x dx[/tex]
[tex]p^2 = -\omega^2 x^2[/tex]
[tex]p = i \omega x + C_1[/tex]
[tex]t = \int \frac{1}{i\omega x + C_1} dx[/tex]
[tex]i \omega t = ln|i\omega x + C_1| + C_2[/tex]
[tex]e^{i\omega t} = C_2(i\omega x + C_1) = C_2x + C_1C_2[/tex]
[tex]\frac{1}{C_2}cos(\omega t) + \frac{1}{C_2}isin(\omega t) - C_1[/tex]
[tex]x = Acos(\omega t) + Bsin(\omega t)[/tex] if we set [tex]\frac{1}{C2} = A,[/tex] [tex]\frac{1}{C1} = B,[/tex] and let [tex]C_1 = \frac{1}{C_2}isin(\omega t) - \frac{1}{C_1}sin(\omega t).[/tex]
bitrex said:
To finish up:
Why didn't the constant make an appearance in your second line?
[tex]p dp = -\omega^2x dx \implies p^2=-\omega^2x^2+C_1 \implies p=\sqrt{C_1-\omega^2 x^2}[/tex]
Carelessness. I'll try it again.
I think I'm a little closer now. Continuing from the dropped constant and substituting into p = dx/dt we have:
[tex]\frac{1}{\sqrt{C_1 - \omega^2 x^2}} dx = dt[/tex]
Make the substitution [tex]x = \frac{\sqrt{C_1}}{\omega} sin\theta[/tex]
[tex]\int \frac{\sqrt{C_1} cos\theta}{\omega C_1 cos\theta} d\theta = \int \frac{\sqrt{C_1}}{\omega C_1} d\theta = \frac{\sqrt{C_1}}{\omega C_1}\theta + C_2[/tex]
So [tex]t = \frac{\sqrt{C_1}}{\omega C_1} sin^-1(\frac{x \omega}{\sqrt{C_1}} + C_2)[/tex]
And solving for X in terms of t I get:
[tex]\frac{\sqrt{C_1}}{\omega} sin (\frac{\omega t C_1 - \omega C1 C2}{\sqrt{C_1}})[/tex]
Not sure this is entirely correct, it's closer though! The first term we can call B because the constant swallows up the omega and square root, but as for the terms inside the sin() I'm not so sure. I know I can find the second solution by substituting y2 = y1*v into the original equation, where y1 = B sin (wt).
The [itex]C_1[/itex] in the denominator should be [itex]\sqrt{C_1}[/itex], so you get
[tex]\int\frac{dx}{\sqrt{C_1 - \omega^2 x^2}}=\frac{\theta}{\omega}+C_2[/tex]
Why is [itex]C_2[/itex] inside the arcsine?
[tex]\frac{\theta}{\omega}+C_2=\frac{1}{\omega}\sin^{-1}\left(\frac{\omega x}{\sqrt{C_1}}\right)+C_2[/tex]
I see it now. It's been months since I've worked on this stuff, and as you can tell I'm pretty out of practice. Ugly careless mistakes. :frown:
  • · Replies 105 ·
13K
