Second order homogenous with variable coeffecients
  • Context: Graduate
  • Thread starter Thread starter Terilien
    Second order Variable
Linear second-order differential equations with variable coefficients, represented as y'' + α(t)y' + β(t)y = 0, require specific forms for α(t) and β(t) to find solutions. Substituting y(t) = e^{r(t)} leads to a transformed equation that may not simplify the problem. The method of Frobenius is often a last resort for finding series solutions, which typically do not yield closed forms. Certain types of equations, such as Euler-type or equi-potential equations, may allow for explicit solutions depending on the coefficients involved.
  • Understanding of linear second-order differential equations
  • Familiarity with the method of Frobenius
  • Knowledge of series solutions in differential equations
  • Basic concepts of variable coefficients in differential equations
  • Research the method of Frobenius for solving differential equations
  • Explore Euler-type equations and their solutions
  • Study series solutions for linear differential equations with variable coefficients
  • Investigate specific forms of α(t) and β(t) that allow for closed-form solutions
Mathematicians, physicists, and engineering students dealing with differential equations, particularly those focusing on variable coefficients and series solutions.
Terilien
In general how do we deal with linear second order differential equations with variable coeffecients?
In general, you can't. You have to specify the form of those coefficients and hope to match it to an equation for which there is a known solution, probably involving a substitution or two along the way. (Unless it lends itself to direct integration, or something.)
Which equation are you concerned with?
why can't you just plug in in e^rt like you do with the constant coefficient ones and just let r be variable(guessing)? For example when you plug e^rt into the homogenous equation you can find r by solving a quadratic equation involving the coffecient. You need to solve for r. however since in this case the coeeficients depend on time, can't we just have variable solutions (r). note that I haven't thought about this much.
I was just curious as the notes I found didn't discuss them much.
Let's say your equation is
y^{\prime \prime} + \alpha(t) y^{\prime} + \beta(t) y = 0
where alpha and beta are arbitrary functions. Now, try your method of subbing
y(t) = e^{r(t)}
bung this into the first equation, and you get
r^{\prime \prime} e^{r(t)} + r^{\prime 2} e^{r(t)} + \alpha(t) r^{\prime} e^{r(t)} + \beta(t) e^{r(t)} = 0
Now, divide out the expoenents, and your equation becomes
r^{\prime \prime} + r^{\prime 2}+\alpha(t) r^{\prime} +\beta(t) =0
So, you now have a different equation, but, more than likely it's not one which is any easier to solve-- unless you get lucky.
Note however, this new one is effectively a first order equation -- i.e. by letting q(t) =r^{\prime}(t).
Err... if you want ot find out what kind of second-order equations are soluble, you can look here. They also have some solutions of PDEs on other pages.
Typically, series solutions are used for linear differential equations with variable coefficients.
decomposition in series...
Is general recipe ,but sometimes such eqs can be solved explicitely and in finite ,closed form.
It depends on \alpha(t),\beta(t) functions coefficients involved.
The brute force method, usually a method of last resort is the method of frobenius. The problem is you'll generate infinite series solutions which rarely have a closed form. The method is necessary for laplaces equation in cylindrical and spherical coordinates.
Yes, particularly "Euler type" or "equi-potential" equations.
Strictly speaking, "Frobenius" method only applies to series expansion about regular singular points, not general series expansions.
There is the y(x)=u(x)*v(x)...
solve for v(x), and end up with something like this u'' +(something)u=0
if your lucky enough it's an easy equation...
Edit:If the Diff Eq was this: y'' +a(x)y'+b(x)y=0
then replacing y=v(x)*u(x)
we have this :u''*v+u'(2v'+a(x)v)+u(v"+a(x)v'+b(x)v)=0
Take (2v'+a(x)v)=0 solve for v , then replace in the Eq above.
Then this is what I meant if you were lucky (v"+a(x)v'+b(x)v) should simplify into something related to v in order to solve...
