Second order ODE initial value problem
The problem involves solving a second order ordinary differential equation (ODE) given by y" - y' - 6y = e^-x + 12x, with initial conditions y(0)=1 and y'(0)=-2. Participants are discussing the general solution and specific coefficients derived from the solution process.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to find the general solution and particular solution coefficients by substituting a specific form for y. They express uncertainty about the correctness of their coefficients A, B, and C.
Some participants have pointed out potential errors in the calculation of the coefficient C and have requested clarification on the steps taken. There is ongoing exploration of the calculations involved, with participants seeking to verify and correct the approach without reaching a definitive conclusion.
Participants are working under the constraints of initial value problems and are focused on ensuring that their derived coefficients satisfy the original differential equation. There is a noted emphasis on checking the accuracy of substitutions and coefficient comparisons.
mkay123321
So the question is y" - y' - 6y = e^-x + 12x, y(0)=1,y'(0)=-2
First I found the general solution which came out to be, Ae^3x + Be^-2x
I then Substituted y=ae^-x + bx + c
y'=-ae^-x + b
y"=ae^-x
Then I just compared the coefficients to get a=-1/4, B=-2 and C=-1/6
So I am getting y = Ae^3x + Be^-2x -(e^-x)/4 - 2x - 1/6
Im not sure if this is right, I have done the rest but I get some funny answers for A and B so I was wondering if someone could verify if this answer is right. Thanks
Your C value isn't correct; try plugging everything back into the equation and see if you get a different C.
I just tried it again. Got the same answer.
Could you show what you did?
I did ae^-x - (-ae^-x+b) - 6(ae^-x+bx+c) = e^-x + 12x
Then I got e^-x(-4a-1) - b(1+6c) = x(12+6b)
After that I did -4a = 1 so a = -1/4
6c=-1 so c = -1/6
6b=-12 so b = -2
Could you tell me where I am going wrong?
the red one. It is -(b+6c)
ehild
  • · Replies 23 ·
  • · Replies 25 ·
