Seagate ST3750640AS 750GB: Maximum Data Flow and Outer Zone Sectors Calculation
  • Thread starter Thread starter Lynne
    Disk
The Seagate ST3750640AS 750GB hard drive can achieve a maximum data flow of 624 Mbit/s, with an average rotation latency of 4.16 ms. Calculating the number of sectors in the outer zone tracks involves determining how much data can be read in one rotation, which is approximately 36.61 sectors based on the calculations provided. The discussion also touches on the importance of understanding data flow and sector calculations, particularly in the context of Zoned Bit Recording (ZBR). Additionally, a similar calculation for the HITACHI GST ULTRASTAR 15K147 147GB drive reveals that it can read around 11,016 sectors in the outer track. Understanding these calculations is crucial for optimizing data transfer rates in hard drives.
Lynne
Hi,
This is probably a simple question, but not for me.
Seagate ST3750640AS 750GB can provide maximum data flow from disk 624 Mbit/s. How many sectors are in outer zone tracks if average rotation latency is 4.16ms?
I've no idea how to calculete this
I think you'll need some more info:
how much can be stored in a sector? (1bit, 10bit, 100Mbit??)
Then, if you have 624 Mbit/s, how much could you read in one rotation (of the outer track) which lasts 4.16ms?
Thank you for reply!
So 1 sector= 512 bytes
624:4160=0.15 Mbit - can read in one rotation
0.15:8*1000=18.75KB
18.75:0.512=36.61 - sectors in outer track
0.15:8*1000=18.75KB
hmmm, I get something different (try to explain what you are doing more to make things more clear)
Ok, so,
624Mbit/s = 624x10^6 bit/s
4.16ms = 4.16x10^-3 seconds
Therefore in one rotation the harddisk reads:
624x10^6 bit/s x 4.16x10^-3 seconds = 2595840 bits (in one rotation)
Now to convert bits to bytes...
How many bits in a byte? (8 is normal, but i think in modern computing it is 10 bits (maybe 11, can't remember) in a byte if you include the trailing and initial bit. something like [info][01010101][trailing bit])
Either way:
2595840/10 = 259584 bytes
or
2595840/8 = 324480 bytes
Then divide the number of bytes by your cluster size (512bytes) and you should get either:
a)507 clusters (for a byte of 10bits)
b) 633.75 clusters (for a byte of 8bits)
Seeing that the clusters should be round numbers, I would round off answer b) to 634 clusters. What do you think?
Since the old times, the number of sectors per track was constant. I just updated myself and found out that using ZBR (zone bit recording), the bit density remains more or less optimal throughout the disk by assigning different number of sectors/cylinder to different zones. The following link presents a detailed description of the techniques, and hence a better understanding of what information that is required to do the calculation.
http://www.pcguide.com/ref/hdd/geom/tracks.htm
Also, rotational latency refers to the delay required by the arm to switch from one track to the adjacent one. For the 7200 RPM drive, the time for one complete rotation is 60/7200=8.33 ms.
The company claimes a SUSTAINED speed of 78 MB/s, equivalent to 624 Mbit/sec for an 8-bit byte. So the sustained read time per track is 8.33 ms - 4.16 ms = 4.17 ms.
The rest of the calculations are essentially the same as Redargon had done, since 4.17 ms is almost identical to 4.16 ms used in the calculations. However, if the rotational latency had not been exactly half of the rotational time, the results could be different.
@ Redargon
I think your answers are more correct than my and both are valid (in my case).
My problem is I just don't understand how to calculate data flow from disk (media transfer rate) or how to determine number of sectors in disk, ect.
Coud it be fomula:w=\frac{n*512}{t} where n - number of sectors, t- one rotation time, w- data flow from disk.
I know this wouldn't work in Zoned Bit Recording as data flow from outer tracks is faster than from inner but I assume that in this task data flow is constant.
Another similar task I can't calculate:
Disk HITACHI GST ULTRASTAR 15K147 147GB provide maximum data flow from disk 1.128 Gbit/s. How many sectors are in outer zone tracks if rotation speed is 1 500 turn pre min?
I guess:
1500:60 = 250 - rotation pre sec
1.128:250= 0.004512 Gbit can be read after one turn. It 's also 4.512 Mbit = 0.564 Mbytes(4.512:8=0.564)= 564 Kbytes in track
1 sector= 512 bytes
564:0.512=(approximately) 1102 sectors in outer track.
Let me know if I am doing something awfully wrong.
ok, you're on the right track. just one calc error:
1500/60=25 rotations per second, not 250.
then it would be 1.128/25=0.04512Gbit per rotation.
0.04512Gbit= 45.12Mbit= 5.64MB (assuming 8bits per byte)= 5.64x10^6 Bytes (per rotation that can be read)
so, then 5.64x10^6/512 = 11015.625 sectors, so around 11016 sectors
oh, and I think your formula looks ok too. (just remember to keep your units consistent) If you use t, rotation time in seconds, then you will get an answer in bytes/s with that formula, as you are multiplying by 512, which is bytes per sector
yip, sounds more reasonable especially since it is a 15K147
I'm very sorry for mistyping here, it is actually 15 000.
15 000:60=250
Thanks for helping me out!
  • · Replies 21 ·
15K
  • · Replies 23 ·
37K
