Projectile Motion: Achieving a Semicircular Trajectory without Calculus
  • Context: Undergrad
  • Thread starter Thread starter JackFyre
    Trajectory
To achieve a semicircular trajectory for a projectile, one must consider the effects of gravitational force and initial velocity. The discussion highlights that under the near-earth approximation, where gravitational acceleration (g) is constant, true semicircular trajectories are not possible; trajectories will be parabolic or linear. For circular motion, one can utilize the concept of circular orbits, as described by the gravitational force equation. An alternative method to create a semicircular path involves using a tethered projectile, which can achieve this trajectory when launched vertically with sufficient velocity.
  • Understanding of gravitational force and its effects on projectile motion
  • Familiarity with the equations of motion in classical mechanics
  • Knowledge of circular motion and gravitational orbits
  • Basic concepts of tethered motion and its applications
  • Study the equations of motion under constant acceleration in classical mechanics
  • Explore the Kepler problem and its implications for celestial mechanics
  • Learn about circular motion dynamics and the role of centripetal force
  • Investigate practical applications of tethered projectiles in physics experiments
This discussion is beneficial for physics students, educators, and enthusiasts interested in understanding projectile motion, gravitational effects, and practical applications of mechanics without calculus.
JackFyre
Hey Folks!
I've got a longish one-
At what angle must you release a projectile to achieve a semicircular trajectory(neglecting air-resistance)? Would the initial release velocity matter? and would the same criteria hold true if the value of g were different(on the moon for example)? and is there any way of proving all this without calculus?
Are you looking at the "near-earth approximation", where the gravitational field ##\vec{g}=\text{const}##. Then you never have a semicircular trajektory, because all trajectories are either parabolae or straigt lines, as can be easily seen solving the equation of motion,
$$\ddot{\vec{x}}=\vec{g}.$$
Since ##\vec{g}=\text{const}## you just have to integrate twice with respect to ##t## and working in the intia conditions,
$$\vec{x}(t)=\vec{x}_0 + \vec{v}_0 t +\frac{1}{2} \vec{g} t^2.$$
You can of course have circular orbits around the Earth, for which
$$\vec{g}=-G m_{\text{earth}} \vec{r}/r^3,$$
where now the coordinate origin is at the center of the Earth.
This problem is of course a bit more difficult to solve, but you find it in any textbook on mechanics (just look for "Kepler problem").
Another option would be to tie a rope to the projectile, anchor the rope some distance away, and fire the projectile straight up with some minimum velocity. That would cause the projectile to travel in a semi-circular arc, centered at the anchor point on the ground. :wink:
  • Haha
  • Haha
  • Wow
Thanks. Makes it clear.
  • · Replies 17 ·
18K
