Sending Email Problems with Multiple ISPs: Can Someone Help?
  • Thread starter Thread starter FulhamFan3
    Email Multiple
The discussion revolves around issues related to sending emails using a POP3 email account when connected to different ISPs. Participants explore the challenges of SMTP server connectivity when using various internet connections, particularly in relation to ISP restrictions and potential port blocking.
  • One participant describes the inability to send emails when using a friend's internet connection, suggesting that either a port may be blocked or that SMTP access is restricted to their ISP's network.
  • Another participant explains that ISPs typically allow SMTP access only from their own netblocks to prevent spam, which aligns with the original poster's experience of being unable to send emails when not connected to their ISP.
  • A suggestion is made that using the ISP's webmail service could provide a workaround for sending emails, although it would not allow the use of the preferred email client.
  • A later reply indicates that one participant has resolved their issue by using a third-party SMTP server for a fee, allowing them to send emails from different connections.
Participants generally agree on the idea that ISPs restrict SMTP access to their networks, but there is no consensus on the best solution for sending emails when using different ISPs. Multiple approaches are discussed without a clear resolution.
Limitations include potential assumptions about ISP policies, the specific configurations of email clients, and the varying capabilities of different ISPs regarding SMTP access.
FulhamFan3
I have a POP3 email account. I have a laptop and receiving email is no problem for me where ever I go. However sending email is. When I send my email from home I have no problems. But when I go to a friend's house and use their connection it fails to connect to the SMTP server. From this I can only guess two things. Either my friend has some port blocked that SMTP needs or my connection needs to be through my ISP for SMTP to work. The blocked port makes more sense to me on it's face however I doubt all my friends have this port blocked
I noticed this same problem when I had two ISP at home a long time ago. I had AOL and Netzero. When receiving POP3 mail I had no problems. However sending mail from my @netzero.com account was only possible when I connected to netzero.
Can someone clear this up for me?
Computer science news on Phys.org
It's typical of most ISPs to allow SMTP access to their netblocks only. This would explain why you can only use your ISPs SMTP server when you use their Internet connection.
What you're trying to do is called `relaying.' Normally, if you were on your ISP's netblock, this wouldn't be a bad thing; however, limiting SMTP access to their netblocks only, prevents spam.
Also, if your ISP has any sort of webmail, this would allow you to send/receive emails through their SMTP/POP3/IMAP servers. The only downside is that you wouldn't be able to use the email client that you typically use.
Thanks. At least I know what the problem is now. I can send email from the same address but from the web instead. It's just annoying to compose email on my fancy program and not be able to use it. But if it cuts down on spam than I'm ok with it.
Except identifying, the problems are supposed to be resolved :) I am using smtp server from http://smtp.com, for a few bucks per month I was able to set my outbound at laptop and configure iPhone to their server as well.
  • · Replies 67 ·
