Seperating a Summation problem.
  • Thread starter Thread starter DKATyler
    Summation
DKATyler
[SOLVED] Seperating a Summation problem.
The Problem:
Separate a sum into 2 pieces (part of a proof problem).
Using: [tex]X=<br /> \sum^{n}_{k=1}\frac{n!}{(n-k)!}[/tex]
Solve in relation to n and X:
[tex] \sum^{n+1}_{k=1}\frac{(n+1)!}{(n+1-k)!}[/tex]
[tex] \sum^{n}_{k=1}[\frac{(n+1)!}{(n+1-k)!}]+\frac{(n+1)!}{(n+1-[n+1])!}[/tex]
[tex] \sum^{n}_{k=1}[\frac{(n)!}{(n-k)!}*\frac{(n+1)}{(n+1-k)}]+\frac{(n+1)!}{(n+1-[n+1])!}[/tex]
[tex] (n+1)*\sum^{n}_{k=1}[\frac{(n)!}{(n-k)!}*\frac{1}{(n+1-k)}]+(n+1)!}[/tex]
I think this is fairly close but, I have no way of getting rid of the 1/(n+1-k) term.
Can you show that [tex]\sum_{k=2}^n \frac{n!}{(n-k+1)!} \ + \ \frac{n!}{(n+1-(n+1))!} = \sum^{n}_{k=1}\frac{n!}{(n-k)!}[/tex]?
If you do that, you can express [tex]\sum^{n+1}_{k=1}\frac{(n+1)!}{(n+1-k)!}[/tex] as a summation starting from k=2. Then you should be able to get the desired expression.
Try it out for some values of k and n, then you'll see a pattern.
In general the pattern is [tex]\sum_{k=1}^{n}f(k) = \sum_{k=2}^{n} f(k-1)\ +\ f(n)[/tex]
That helps quite a bit.
[tex] n!+\sum^{n}_{k=2}\frac{n!}{(n+1-k)!}=\sum^{n}_{k=1}\frac{n!}{(n-k)!}=X[/tex]
So continuing from this step:
[tex] (n+1)*\sum^{n}_{k=1}\frac{n!}{(n-k+1)!}+\frac{(n+1)!}{(n+1-[n+1])!}[/tex]
changing the Index and adding/subtracting n!
[tex] (n+1)*(1-n!+n!+\sum^{n}_{k=2}\frac{n!}{(n-k+1)!})+(n+1)![/tex]
Solves the Equation in terms of n and X:
[tex] (n+1)*(1-n!+X)+(n+1)![/tex]
Yep, that worked, now I can complete the rest of the proof :) Thank you very much. How to mark this "[solved]?"
Go to your first post in this thread, at the top right hand corner of the post marked "Thread Tools"
