Homework Helper
- 2,324
shmoop said:How did you calculate the resistance with those current values?
In a series circuit, the current value is supposed to stay the same, and the voltage value is supposed to vary.
That's what got me thinking that you didn't have all three resisters in series when measuring the current through each resistors . If you changed the circuit and connected each resistor on it's own to the power supply (or put them all in parallel) then the voltage would be the same each time and the current values would change. The calculated current values are very close to the figures you measured if you allow for the mA vs A error.
So using your data with the current corrected to mA...
R1 = 5.06/(50.2 * 10-3) = 100.8 Ohms
R2 = 5.03/(23.0 * 10-3) = 218.7 Ohms
R3 = 5.05/(10.9 * 10-3) = 463.3 Ohms
Which are close to the correct values.
