Series solution up to a term, power series
The discussion revolves around solving the initial value problem (1-x)y,,+xy,-2y=0 using a power series approach, specifically finding the series solution up to the x^6 term. The proposed solution takes the form of a power series, leading to a recurrence relation that includes coefficients a_n, a_n+1, and a_n+2. Participants clarify that it is necessary to define initial conditions a_0 and a_1 to solve for a_n+2, which is derived from the recurrence relation. An algebraic error is noted in the calculation of a_n+2, emphasizing the importance of careful manipulation of terms. The conversation highlights the complexity of handling series solutions for second-order differential equations.
dp182
consider the initial value problem (1-x)y,,+xy,-2y=0 find the series solution up to the term with x6
(1-x)y,,+xy,-2y=0
assuming the answer has the form \Sigmaanxn
that gives y,,=\Sigmananxn-1 and y,,=\Sigman(n-1)anxn-2 then plugging these back in and getting rid of the xn-2 and xn-1 you get the equation \Sigma(n+2)(n+1)an+2xn-\Sigman(n+1)an+1xn+\Sigmananxn-2\Sigmaanxn so what I'm wondering is how do you replace the an+1 with an an so you can solve for an+2
hi dp182! :smile:
dp182 said:
… how do you replace the an+1 with an an so you can solve for an+2
just subtract 1 from everything :wink:
(eg ∑an+1xn = ∑anxn-1)
You don't. The recurrence relation involves an, an+1, and an+2. There's nothing wrong with that.
It makes sense that the recurrence relation for a_n+2 involves a_n+1 and a_n. It would require you to define a_0 and a_1 and Second order differential equations require two boundary/initial conditions for a solution.
So If I solve for an+2 I get an+2=n(n+1)an+1+an(2-n)/(n+2)(n+1) so to get my terms up to x6 I will just input values of n, so my series will be in terms of a0and a1?
Yup, but you made an algebra error solving for an+2 (or omitted very needed parentheses).
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 22 ·
