Is \Re^\infty Used for Sets with Zero Elements?
In summary, we discussed the notation for a countable array with all but finitely many terms being zero, denoted by $\Re^\infty$. This is also known as the coproduct, and in the category of vector spaces, it is the smallest set with this relation. The product, on the other hand, is the dual definition and has projections onto the factors. In general, the coproduct depends on the category in which it is defined, and in the category of SET, it is called the disjoint union.
Palindrom
263
Is it correct that [tex]\[
\Re ^\infty = \left\{ {\xi \in \Re ^N \left| {\exists n \in N:\forall k > n\,\xi _k = 0} \right.} \right\}
[/tex], N denoting the natural numbers?
If not, is there another symbol for the left hand side of the equation?
Is this also used with any other set containing a zero element?
try writing it more clearly in english and not latex so that it gets the spacing correct. As it is you appear to be asking for the correct notation for a countable array (x,y,z,.) where all but finitely many terms are zero. This is the coproduct you want, not the product.
[tex] \oplus \mathbb{R}^i \ i \in \mathbb{N}[/tex]
That's exactly what I wanted. Could you please define coproduct?
Oh, and what was the problem with the spacing?
it looked like "t times zeta" you see.
the coproduct is exactly "coutable array" with all but finitely many entries zero. it has a better categorical universality definition. given sets X_i i in I some index the coporduct, when it exists is the object sum X_i with maps from the X_i to the sum X_i that are "inclusions" and that is universal with respect to this definition
sounds nasty, right?
eaiser to think in terms of finite (co)products of vector spaces.
if X and Y are vector spaces, then the coproduct is a vector space with inclusions from X and Y that is smallest with this relation and no other. Thus it is precisely the set of ordered pairs (x,y) with x in X and y in Y, ie if X=Y=R then it is R^2., and the inclusions are x to (x,0) and y to (0,y)
The product is the dual defintion, that is it comes with projections onto the factors X and Y, and it so happens that for a finite number of spaces this is the same as the coproduct, and the maps are
(x,y) to x and (x,y) to y.
when you pass to infinitely many factors they are different.
the product over i of in N R_i is the set of all arrays (x_1,x_2,x_3,...) with x_i in R_i
the coproduct is the set of arrays (x_1,x_2,...) where only finitely many are nonzero (or equivalently x_i is zero for all i sufficiently large).
O.K., great, that's just what I wanted to know, thanks.
One last question on the subject- what happens if X_i don't have a zero element?
We are talking about these things as *vector spaces* and not as sets so they must have the zero vector in them. It was as a vector space that i took the coproduct, since *you* wanted to the zero element to be distinguished in this way. I wansn't talking about the set coproduct. (see below)
However, in general, the coproduct depends upon the category in which you are working; part of the definition of coproduct is the existence of certain maps, and the form of these maps is determined by the category.
In the category SET the coproduct is called the disjoint union. and is not the same as the coproduct of vector spaces.
Thank you so much, you've been of great help.
1. What is \Re^\infty used for?
\Re^\infty is used to represent sets with an infinite number of elements. It is a way to denote the cardinality, or size, of these sets, and is often used in mathematics and computer science.
2. How is \Re^\infty different from regular infinity?
\Re^\infty is not a number, but rather a symbol to represent the concept of an infinite set. It is used to describe sets that have an uncountable number of elements, whereas regular infinity (\infty) represents a number that is larger than any finite number.
3. Can sets with zero elements be represented using \Re^\infty?
Yes, sets with zero elements, also known as empty sets, can be represented using \Re^\infty. This is because \Re^\infty represents all possible sizes of sets, including those with zero elements.
4. What is the significance of using \Re^\infty for sets with zero elements?
Using \Re^\infty allows us to have a consistent way of representing all possible sizes of sets, including those with zero elements. It also allows for more precise and concise mathematical notation when working with infinite sets.
5. Are there any limitations to using \Re^\infty for sets with zero elements?
While \Re^\infty is a useful notation for representing sets with zero elements, it is important to note that it is only a symbol and does not hold any mathematical value. It is also important to use it correctly in the context of a mathematical statement or proof, as it may not always be applicable or necessary.
  • Set Theory, Logic, Probability, Statistics
  • Math POTW for University Students
